my amp is not getting any power and my deck is now not working...my deck does not havea fuse that is vissable in the back of it and my amp fuse seems to be fine. what ahould i do? i think my ground and power touched at teh terminals somehow.....
Take it to Best Buy or someone like that! Have a pro look at it and tell you whats wrong with it. It sounds like you blew a fuse look in your fuse panel drive side door on the side of dash.
i found the fuse in the fuse box..and it was blown.. but then i replaced it and it blew the second i turned on the radio... the radio actually didnt even turn on..and i had the amp disconnected from the deck except for the remote
