New System Suggestions - FirebirdV6.com/CamaroV6.com Message Board
  • New System Suggestions
    im starting to save money for a system and im in the process of planning what to get. im replacing all the stock speakers with infinity kappas. i want to go with the milhouse box with 2 10" kicker comp vrs DVC. as for the amp, im unsure of. i want a mid class amp. not cheap, not expensive. what do you guys suggest that will put out between 800-1000 watts???
    JBL BP1200.1
    Around 1300WRMS @ 2ohm. Stable to 1 ohm.
    [ January 22, 2003: Message edited by: 96firebird311 ]</p>
    Red 96' A4 Firebird
    Audio Audio and Autotek
    Check it out here!
      phoenix gold has in there qx line a 900 watt mono block :D :D :D :D here are the specs
      Model: QX900.1d
      - 900 Watts Total
      - High Efficiency Class D Mono Block Amplifier
      - 475 Watts x 1 @ 4 Ohms Mono (12.6v)
      - 900 Watts x 1 @ 2 Ohms Mono (12.6v)
      - Continuously Variable 18 dB/Oct Low Pass Crossover
      - 15-55Hz 18 dB/Oct Octane Subsonic Filter
      - S/N Ratio: &gt;100 dB
      - Black Color with Superbrite Blue LED
      - Fully Complimentary Output Stage
      - Configured Thru Output
      - Twin "T" Bass EQ Circuitry
      - High or Low Level Inputs
      - Low Pass Level (LPL) Control
      - Remote Monitoring (RMD) Port
      - Dimensions 16-3/4"(L) x 9.5"(W) x 2"(H)
      it can be had off of ebay for $300.00 new
      [ January 23, 2003: Message edited by: grndlvl ]</p>
      97 \'maro 3.8L with magana flow exhaust and K&N air filter
