My rear window defogger quit working Saturday. I press the button and nothing will happen. It doesn't click or light up when I try to turn it on. Has this happened to anyone else? Could it be the switch that went bad or is there some other type of electronic failure that could cause this?
Thanks
Matt<br />1999 Black Camaro 3.8 V6 Y87<br />T-Tops, pacesetters, 3\" Dynomax cat-back, 3\" catco, Whisper Lid K&N<br /><a href=\"http://community.webshots.com/album/78349582bpbFco\" target=\"_blank\">Click here for Pictures</a><br /><a href=\"http://www.cardomain.com/ride/2194607/1\" target=\"_blank\">http://www.cardomain.com/ride/2194607/1</a>
It has a fuse, it has a 30 amp fuse, it's one of the big silver ones. Could be that, mine never has worked in mine and I checked the fuse and it didn't even have one so I put window fuse in it's placeand it worked. If you have power windows just swap the fuses and see if that fixes it.
[ February 04, 2004: Message edited by: O2Bsogood ]</p>
1999 Silverado- Bagged, colormatched and rollin on stock chrome 16\'s<br />Make love not war, hell do both, get married
i have a 1997 and mine comes on but only for about 1-2min (expose to be 10min) at a time, and then won't come on any more for a while?????? any ideas??????????????????/
www.turbov6camaro.com 1997 3800 Series II Camaro 4600 Stall for my ride to the mall :chug: 7.18 @ 99.77 1/8 -1.8x sixty (current quickest v6 fbod) 11.23 @ unk 5 1/4 - 7.19 1/8 - 1.83 sixty
<blockquote>quote:</font><hr>Originally posted by viper04af: i have a 1997 and mine comes on but only for about 1-2min (expose to be 10min) at a time, and then won't come on any more for a while?????? any ideas??????????????????/<hr></blockquote>
the fuse/(really a circuit breaker) is getting worn out, and should be replaced.
Many people on ls1.com complain of that, some people replace the circuit breaker, with a fuse, and that is an option. But i would just go buy a new breaker, see if that fixes it.
Either way DO NOT just bypass the breaker.
Ryan.
1998 Ws6 Ta M6 #370 Bright Red<br />Custom \"NX\" style switch panels $35<br />Plug in fan switches $50 <br />SLP lid, Pro 5.0, Corsa, Custom Fan switch<br />....vortech waiting to be installed.
<blockquote>quote:</font><hr>Originally posted by slow:
Ryan.<hr></blockquote>
i'm guessing you mean the button you push? i know what a circut breaker is, but is that what you mean? lol know were to find it? PN bye chance?
no, the breaker is the silver box in the drivers side fuse panel.
they are auto-resetting.
auto parts stores should have one, you can try swapping the one from the power windows to see if that will fix it.
Ryan
yes, the silver thing is not a fuse, it is a circuit breaker. and it has a problem of only working for short periods as it gets old (sometimes brand new). just reiterating the previous post to affirm what was said.
Your sig is the most important part of your message. Make sure that you list EVERY single thing that you have done to your car so that we can all go \'oooh!\' and \'Ah!\'. Please make your sig consistently longer than anything else you post. Please include your lengthy sig with EVERY single post you make during a reply, even if you only reply with a monosyllable grunt.
i just put in a new breaker it seems to help, i still would like it to stay on longer.
viper go out and buy a 12v 30a breaker from any auto part shop. it should be labled but if not, open your door look at your fuse box in the lower right their will be the breaker (if you have power seats it will be the breaker on top) pull it out put the new one in and your done
1998 green camaro, bear rotors.<br />It\'s not how much money you have, It\'s how many toys you have.
<blockquote>quote:</font><hr>Originally posted by O2Bsogood: It has a fuse, it has a 30 amp fuse, it's one of the big silver ones. Could be that, mine never has worked in mine and I checked the fuse and it didn't even have one so I put window fuse in it's placeand it worked. If you have power windows just swap the fuses and see if that fixes it.
[ February 04, 2004: Message edited by: O2Bsogood ]<hr></blockquote>
I just switched the window fuse/breaker with the defogger and started it up to check it. The windows worked and the defogger still did not work. That leads me to think that the breakers are working and that it is something else?
camaro99 next time you turn on the defroster feel how hot the breaker gets, the way a breaker works is that the more amps go in to it it heats up a bar with copper on one side and steel on the other. when the copper gets hot it bends the bar pulling it away from the conntacts. what im saying is i dont know what the problem is but this may be it. try a fuse but make sure you turn it off because the breaker is what turns the defroster off. personaly i would not do this because i dont want to fry my defroster by leaving it on to long but it will tell you if the breaker is the problem good luck with figuring it out.
breakers normally are not used for the timing circuit.
are you sure that is the way GM designed it? I would not be suprised, as that would lead to the problems that people have, but the only way that it would work right, is to have the breaker undersized, so it trips.
Im guessing that the timing is done low current before the relay for the defroster in the AC controller. But i don't have wiring diagrams to verify. That is the proper operation. I did go to my car, took the breaker out, turned on the defroster, put breaker in, turned on, took breaker out, light went off, put breaker back in, light back on, repeated this 8 times, so i am fairly sure the breaker is NOT what is designed to turn the circuit off, it just does, when they get crappy.
Ryan
[ February 06, 2004: Message edited by: slow ]</p>
<blockquote>quote:</font><hr>Originally posted by viper04af: oh ok those, lol the timing circuit, same thing as the turn singals only differant fuction. thanks cuase that was really been bugging me
BTW its been a year since i seen my car are those labled so i know witch one to replace?<hr></blockquote>
breakers are not timing circuits. and no they are not the same as a turn signal, in a different function.
Breakers are designed to open a circuit, when the load becomes greater than the breaker is rated for, this is to protect the wiring only.
Ryan
I went to the chevy dealer to check the price to get a new switch and they said it would be $177 to get a swich because it comes built in with the hvac controls. I have no clue what could be wrong with it and I don't really want to pay that much money for something that may or may not fix it.
btw...the breaker is working
