Will component speakers work with a Monsoon system? My driver's side speaker went out, and figured I could go component since they use a lower RMS requirement. I was planning on getting these: http://www.bestbuy.com/site/olspage....oryId=cat03079
They told me they would work, but it will not be as loud. Any opinions?? I don't feel like rewiring everything and yes I do know they are rated at 4 ohms when I need 2ohms, but they said I should still get some decent sound. Thanks
Simple answer: yes, they will work.
Complex answer: They will not be as loud as you will want them to be. You will probably end up turning the volume control on the head unit up to get the desired volume, causing the Monsoon amp to clip. This clipping is what causes the voice coils to burn up, hence blowing your speakers. So while they will work at lower volumes, they will blow at a higher volume.
Eclipse 8443, CDT ES-620s in doors (Clarion APX401.2), IEK, CDT 6X in rear(HU), Image Dynamics ID10v.3D.4 in stealthbox(Clarion DPX1001.2)<br /><a href=\"http://www.sounddomain.com/id/larryfirebird33\" target=\"_blank\">http://www.sounddomain.com/id/larryfirebird33</a><br />borla cat-back, FTRA, whisper lid
Hmmm...well they are installing everything and giving me a 4 yr warr, so if they blow, they will replace them for free. But if I have it at normal listening volume I should be fine. Any other recommendations on what I could do? Thanks!!!
At a normal listening volume, the amp will be using more power though, that's what I was trying to say. It will take more power of the amp to produce the same level of power with the new speakers. And they most likely WILL blow, based on what everyone has done in the past. So, they can keep replacing them for the next for years for you if u want. And when you save up enough money, then buy a compatible HU.
Hmm..okay I guess I will pass on that idea. One more question. Are the speakers in my hatch area supposed to be 4 ohms?? I saw it today and it said 4 ohms Delco. Thanks for your help!
CaLi<br />-=|Sinister Six|=-<br /><a href=\"http://www.villagephotos.com/pubbrowse.asp?selected=756425\" target=\"_blank\">1999 Chevy Camaro Pewter</a><br />Have you ever wanted to know what happens<br />to a 3.8l v6 when you are doing 90mph in <br />2nd gear at 6000 rpm? pics to come soon...
But my code says ULO which = Monsoon right???? Plus I have speakers in all 6 locations. Can anyone clarify this?? Sorry for the wierd questions. I appreciate everybody's time and patience.
the 2 speakers in the b pillar are only mid ranges
the speakers that are in the back seat area are the mids... the 4" are in the very back on the 2 side panels
becuase the most common caar audio speaker is a 4 ohm... I've seen bose speakers that were 6 ohm and someothers 8ohm
