monsoon? - FirebirdV6.com/CamaroV6.com Message Board
monsoon?
  • monsoon?
    how do you know if you have a monsoon sys. or not
    1998 green camaro, bear rotors.<br />It\'s not how much money you have, It\'s how many toys you have.
    Check in the right rear passenger side where the spare tire is to see if there's an amp mounted just above the tire to a black panel. If its there, you have monsoon.
    Also, check your RPO codes on the inside of the drivers door. If you have UNO, that's the Monsoon system with CD. ULO is the Monsoon system with tape.
    Hope that helps.
    [ June 01, 2002: Message edited by: PiLOTLiTE ]</p>
      thanks alot
