Length of RCA's - FirebirdV6.com/CamaroV6.com Message Board
Length of RCA's
  • Length of RCA's
    If i'm running the rca's from my deck to the rear of the trunk, how long should I get them? Also how much 4ga power wire do you think I will need?
    Thanks,
    Dennis
    1996 Camaro RS
    RCAs= where exactly are your amps gonna be? In the spare tire area? Or on the little flat area behind the back seat? Get like an 16-17ft length just to be sure.
    Power wire= again, where are your amps gonna be? Should be roughly the same length....
    [ February 05, 2003: Message edited by: 96firebird311 ]</p>
    Red 96' A4 Firebird
    Audio Audio and Autotek
    Check it out here!
      My amps are going to be on the rear wall of the trunk on a amp rack. By this I mean they will be facing towards the front of the car.
        I've got my amps on the flap that covers the hatch area. I used a 20 ft RCA and had plenty of slack in it, actually about 3 or 4 extra feet. I'd rather have extra length than just barely enough...go with a 20'.
        On the power cable, I can't remember exactly how much I used. Less than 20 would probably be pushing it. You could get 30 and use the leftover for a ground.
        Good luck. [img]graemlins/thumbsup.gif[/img]
        95 Camaro 3.4L A4<br />Bosch plugs/MSD wires, K&N FIPK , Magnaflow catback, hi-flo cat, B&M Shift+, Dee\'s spacer<br />Kenwood KDX-859, eXcelon Amps, Infinity Kappa 3-way doors and Perfect10 sub<br /><a href=\"http://www.cardomain.com/id/harbins95\" target=\"_blank\">Behold, the raw fury that is known as the 3.4!!!</a>
