I have just bought a set of 652.5i speakers for my 1998 Camaro these are to replace the mid speakers but when I wired them up with the crossover the only thing that they do is buzz Was I sold some defunk speakers or what? I have a set of 42.5i's in the sails and stock in the doors I have a set of 652.5i for the doors but don't want to take the doors apart just to find out that they will not work as well. Do I have bad wireing or bad speakers?
Infintiy Problems
I have the 62.5i's in the sail panels and the trunk panel speaker spots, nothing in the doors, crossovers and hooked up and i have 75 watts rms to all of them, sound awesome, not sure about whats wrong with yours but i would never hook up stock speakers and infinity's in the same system as they both work with different power ranges (use the same amount, but the infinty's need more to sound as they should)1997 Pontiac Firebird 3.9L<br /><br /> - TSP Dyno Tuned<br /> - Bored 0.040<br /> - ARP Rod Bolts / Head Studs<br /> - Custom CAI<br /> - Pacesetter Ceramic Headers / !Cat<br /> - 3\" Catback w/SLP Firehawk Muffler<br /> <a href=\"http://www.cardomain.com/memberpage/649312\" target=\"_blank\">http://www.cardomain.com/memberpage/649312</a>
what do you mean by mid dpeakers, and what do you consider sail speakers?
the sail panels, or B pillars, are normally considered the 6.75 speakere behind your head, and are a "low range speaker" the highs are cut off on these if you have the monsoon system. Since your saying they're buzzing, which sounds like what they would do if plugged into the factory system.
The trunk ones are 4" and that sounds like what you called the sail panels. 42.5i, (guessing by number, that its a 4" speaker)
please give more details on your setup, so we can try to help you.
Ryan1998 Ws6 Ta M6 #370 Bright Red<br />Custom \"NX\" style switch panels $35<br />Plug in fan switches $50 <br />SLP lid, Pro 5.0, Corsa, Custom Fan switch<br />....vortech waiting to be installed.
Yes I got confused on the sail thing. I'm trying to set up a infinty system no more stock. there are 652.5is in the "sails" and 42.4i in the trunk. and I have another set of 652.5i's for the doors. All coming of the stock head unit. There is no highs at all coming out of the "sails" or mid section of the car. also in the doors there are 4 speakers 2 red 2 black should I just attach these to the infinitys or should I try to rought them through the crossovers?98 Camaro 3.8L black with T-Tops, K&N Air fliter, MSD Coil packs, More mods to come<br />web site <a href=\"http://www.wayug.com\" target=\"_blank\">www.wayug.com</a> \"are you down enough\"
does any one know about this?98 Camaro 3.8L black with T-Tops, K&N Air fliter, MSD Coil packs, More mods to come<br />web site <a href=\"http://www.wayug.com\" target=\"_blank\">www.wayug.com</a> \"are you down enough\"
by DongrossmdI’m new. I actually don’t own a Camaro or firebird. I do have a 2000 Camaro 3.8 fly by throttle and 4l60e. This is installed in a 1980 Triumph TR7...1 day ago
by ssms5411Not much going on, replaced my Kenwood double din stereo with a Pioneer double din, the Kenwood had problems. Then replaced my power inverter for my reverse...3 days ago
by 187sharkHi all new to the community here. I have a 2014 RS 6 speed manual... and so about a year ago my tail lights got cracked and eventually the plastic housing...2 weeks ago
by DoodlerHi, everyone. We bought a 97 base model convertible Camaro and someone broke the motor ... Lights were blinking on the dash and that someone ignored the...3 weeks ago
