This is just a quick question for all of you pro's out there. I've got my gain adjusted perfectly on the amp, but I noticed that there are two other controls. One for "Equalizer" and another for "Frequency" The manual really doesn't say much about why these would be adjusted, it only got into detail on the gain. Do you guys know what these two things control, and if I should adjust them?
Heres what the manual says:
Thunder EQ – This equalization circuit is used to enhance the low frequency response of the vehicle’s interior. With up to 18dB of boost and centered at 40Hz, the Bass EQ can be adjusted to meet your own personal taste.
Frequency Control – This control is continuously adjustable from 40Hz through 200Hz at 24dB per
octave. Factory setting is at 40Hz.
Thanks again,
Brent
Thanks again,
Brent
