Amp fuse - FirebirdV6.com/CamaroV6.com Message Board
Amp fuse
  • Amp fuse
    Turned on the stereo and the sub wasn't working so I looked under my hood and saw that my amp fuse was blown. I replaced the fuse, turned the key and it blew out again. Tried it several times and got a blown fuse everytime....any ideas what I can check?
    1997 Supercharged Firebird<br />14.01@99.7mph 2.1 60ft.
    check ur grounds.
    \"Well, we don\'t care how bad-*** some dude\'s N/A Honda S2000 motor is; if you go up against 900+ pushrod ponies and 750 pounds of earth-shaking torque with a wrong-wheel-drive econobox, you\'re gonna get a fast and furious old-school ***-whipping.\"
      Wait stop putting in new fuses you probobly have a short in the wiring or you have an underrated fuse. More details please (watts, size of fuse, how many amps)
      Matt
      \'93 Red 3.4L Camaro<br />Engine: Jet II, Pacesetters, K&N FIPK, Accel Wires, Iridium Plugs, Flowmaster, ASP U/D, 180 Thermo, much more...<br /><br />\'98 Z28 Vert Triple Black A4 Stock for now<br />34000 Miles<br /><br />Not enough room in the sig for my stereo.
        First, DO NOT put a larger fuse in just yet.
        Is that the first time you've tried to listen to your stereo? (new?) Or have you had it liek that for a while? Give all your wiring the once over. Maybe turn the gain down and play it at very low volume....does the fuse still blow?
        Red 96' A4 Firebird
        Audio Audio and Autotek
        Check it out here!
          The stereo is not new, I have had it for several years.
          ROckford fosgate 250 watt amp
          30 watt fuse under the hood is what keeps blowing out
          Fuse blows even with volume down. The instant the key is turned it blows. I took the sub out to go to the track and when I put it back in I started having this problem. I am guessing maybe a wire problem sounds right. Maybe a wire got smashed when I put it back in.
            make sure your ground isnt touching the power at all, on the amp connections.
            make sure the power wire isnt pinched somewhere
