Need radio install help quick! - FirebirdV6.com/CamaroV6.com Message Board
  • Need radio install help quick!
    On the radio I got I need to hook up 3 wires. OK the first one is a power battery. It says connect directly to the battery but isn't there a wire I can splice into? The second one is the ground, it says hook to the vehicle, but isn't there a wire I can splice into? And the last one is the one I have to splice into the ignition so it turns on when the key is on. Which one is that? Thanks guys!
    1995 Patriot Red T-Topped Z28 A4<br /><br />Mystery rebuild in progress.<br /><br />Soon to have 383 ways to beat KBreezy and Shane. :D
    Battery: get a 12V tester and see which wire has a constant i *think* its a red wire back there.
    Ground: never use the stock ground with an after market deck see if you can ground it somewhere, be sure to sand down the area to the paint.
    ignition: this is where the tester comes in handy again. I *think* this is the yellow wire this wire should have no power with the car off but power when you put the key in the acc position or when the car is running.
    I hope that helps...
      Pin#.................Color...........…….......Func tion
      1......................Grey....................... ..Front Left Speaker -
      2......................Tan........................ ...Front Left Speaker +
      3......................Dark Green.............Front Right Speaker -
      4......................Light Green............Front Right Speaker +
      5......................Black .................Ground
      6......................Brown..................Illu mination
      7......................Grey...................Dimm er
      8......................Pink...................Powe r Antenna
      9......................Yellow.................12V Ignition
      10.....................Orange.................12V Constant
      11.....................NA.....................NA
      12.....................NA.....................NA
      13.....................NA.....................NA
      14.....................Dark Blue..............Steering Wheel Controls
      17.....................Light Blue............ Right Rear Speaker -
      18.....................Dark Blue..............Right Rear Speaker +
      19.....................Yellow.................Left Rear Speaker -
      20.....................Brown..................Left Rear Speaker +
      As CAMAROWIDBASS said, do not use the factory ground. Make your own straight to chassis.
      Red 96' A4 Firebird
      Audio Audio and Autotek
      Check it out here!
