AMP mounting - FirebirdV6.com/CamaroV6.com Message Board
AMP mounting
  • AMP mounting
    Ok so Ive been reading alot on where to mount the AMP since I have the hatch box that fills the trunk space up and I have decided to get some plywood cut it to fit in the space where the spare tire goes....its going to be a tight squeeze but it will fit...I tried it with some cardboard cutout's and it worked. Anyway should I carpet it or paint it....its going to be out of view so Im undecided. Whats your opinion and if yo have a better idea on where to mount it out of site let me know....thanks
    Underneath the subs wont work.....not enough room.
    1996 Firebird-Y87:SLP Cold Air Intake,Y87 Perf. Package: 3.42 Gears w/ Zexel-Torsen LSD, Sport Steering(14.4:1 ratio), Dual Exit Exhaust,800 watt Pioneer Amp and Two 10\' subs with a custom trunk enclosure.
    i put mine on the back above the well just made sure i didnt go through the metal just mounted it in the carpet and it's stayed there gas tank is right there so i didnt wanna go into that can of worms
      I need to see if theres room for it behind the box....Ill see
