Mosoon HU but no UNO code !!!! - FirebirdV6.com/CamaroV6.com Message Board
  • Mosoon HU but no UNO code !!!!
    I just checked the codes on the door of the car and I didn't find the code "UNO" which according to the database is the code that identifies that the car came with the Monsson HU. Still, my HU says Monsson and so far I haven't been able to find the amp on the back.
    Can anybody explain this for me please?
    [ May 25, 2005, 06:25 PM: Message edited by: Georghino ]
    2002 Arctic White Firebird W68<br />Installed: FTRA, Carbon Fiber Whisper Lid, K&N Filter, Transgo Shift Kit, Corvette Servo, 160º Thermostat.<br />Appearance: Potenzas RE750 245\'s, 3M Tint 20% All Around, Clear Corners.<br />FOR SALE: HPP3
    Are you the first owner? Maybe a previous owner swapped in a monsoon HU. I think it can run without the amp. Even in monsoon equipped cars, I know at least the two front speakers are powered from the HU.
    Yes, I know \"Artic\" should be spelled \"Arctic\". Can any of the mods change this?
      Look on the drivers door again and see if you see any of the following codes:
      W54-10-speaker Entertainment System, Cassette, w/ External Delco Amp
      W55-10-speaker Entertainment System, CD-Player, w/ External Delco Amp
      U1T- Standard single CD-Player w/AM-FM stereo, w/HPS
      U1C- Standard single CD-Player w/AM-FM stereo.
      U1A- Single CD-Player w/ 10-speakers (no external amp)
      UU8- Cassette Player w/AM-FM Stereo, w/HPS
      UN6- Cassette player w/AM-FM Stereo
      2006 Tiburon
        The amp is mounted way back in the hatch on the passenger side tucked behind where the spare tire is. Remove the spare tire and look for a black plastic plate tucked inside the rear fender area. There should also be a very thick wiring harness full of wires and a huge plug that plugs into the amp...see picture bellow:
        2006 Tiburon
          Well, I checked the codes again and I found the W55 (10-speaker Entertainment System, CD-Player, w/External Delco Amp.) I wonder what's the difference between this and the Monsoon code. Like I said my HU says "Monsoon". They seem to be basically the same. Anyone?
          Also, I will look for the amp tomorrow. It's got to be there somewhere now that I know there is in fact one.
          Thanks for your help.
          p.s. I knew my stereo had to be the Monsoon kind. It sounds really good. They did a great job putting together that sound system. Still, an upgrade wouldn't hurt.
            Not sure why GM did it that way either, I have the W55, too. From what I understand, everything is the same as a Monsoon but instead of saying "Monsoon" it just says AC/Delco on the amp and speakers.
            2006 Tiburon
