REM wire hook up? - FirebirdV6.com/CamaroV6.com Message Board
REM wire hook up?
  • REM wire hook up?
    Im hooking up a amp in a friends car, 2000 camaro, where can i hook up the REM wire, which wire behind the head unit, or are there are wires i can use in the rear of the car.
    Go Big or Go Home
    Use the "Pink" wire behind the factory headunit.
    2006 Tiburon
      i got it, on camaros its a yellow wire
      Go Big or Go Home
        no yellow is power?????
          I found this in another post
          Pin#.................Color...........…….......Func tion
          1......................Grey....................... ..Front Left Speaker -
          2......................Tan........................ ...Front Left Speaker +
          3......................Dark Green.............Front Right Speaker -
          4......................Light Green............Front Right Speaker +
          5......................Black .................Ground
          6......................Brown..................Illu mination
          7......................Grey...................Dimm er
          8......................Pink...................Powe r Antenna
          9......................Yellow.................12V Ignition
          10.....................Orange.................12V Constant
          11.....................NA.....................NA
          12.....................NA.....................NA
          13.....................NA.....................NA
          14.....................Dark Blue..............Steering Wheel Controls
          17.....................Light Blue............ Right Rear Speaker -
          18.....................Dark Blue..............Right Rear Speaker +
          19.....................Yellow.................Left Rear Speaker -
          20.....................Brown..................Left Rear Speaker +
          Go Big or Go Home
            there is no pink wire behind my deck
            Go Big or Go Home
              There is no wire in the camaro (no factory power antenna). You can insert a pin into the harness on the radio. Its the 3rd hole from the right on the top (looking at the back of the radio)... pin #8 as stated in that info above.
              \'98 Camaro V6<br />Appearance... pleasing<br />Performance... just a little extra air.
                Yes, the Yellow wire will work too since its switched on/off with the key.
                I knew that Camaro's don't come with power antennas but I thought the pink wire would atleast still be in the harness. :(
                2006 Tiburon
                  haha, you guys dont have a blue wire? are we talking about stock deck or aftermarket? because the blue wire is what you need, the blue wire is usually the power ant. wire.
                  Black 1996 3.8 Firebird T5, SLP CAI, Pacesetter Ceramic Headers,160* t-stat, PCMforLess Tune, Flowmaster American Thunder catback, Car Sounds Cat, custom s-pipe, MSD coils and wires, NGK plugs, 3.42 posi rear, B&M Ripper, 245/50 BFG-G-force's
