Need Help - FirebirdV6.com/CamaroV6.com Message Board
Need Help
  • Need Help
    Ok, i got everything wired, amp to stock deck, I ran
    power wire from the battery, got good grounds, ran the line out converter from rear spreakers, got turn on wire from deck, when the car is turned on not running the subs play fine, but when you turn the car on (engine running) the subs start pulsing real bad to full excursion.
    What is causing this, i unhook the amp and if no can help im just gonna take it to a shop
    oh yea its a 2000 camaro
    Go Big or Go Home
    Check your speaker wire connections......make sure you have done it right and their tight and secure.
    1996 Firebird-Y87:SLP Cold Air Intake,Y87 Perf. Package: 3.42 Gears w/ Zexel-Torsen LSD, Sport Steering(14.4:1 ratio), Dual Exit Exhaust,800 watt Pioneer Amp and Two 10\' subs with a custom trunk enclosure.
      check your ground
      make sure its sanded down to the bare metal
        thanks for the help so far, i will try a new ground and see if that helps
        Go Big or Go Home
          anyone else ever have this problem
          Go Big or Go Home
            Anyone
            Go Big or Go Home
