I just bought a HO Alternator off ebay and it said I needed 4 guage power wire from the alternator to battery well I want to put 1/0 guage instead and want to use it on the ground too
do yall have any writeups on how exactly to do this and what I need ie. how much wire and what terminals and how many
thx
Black 1996 Camaro 3800 Series II with tan leather seats<p>Modifications: K&N Filter, 2 12\" Power Acoustik, 1800 watt Rockford Fosgate Amp, 600 watt Rockford Fosgate Amp, Custom Box, White Gauge overlay with switch, Custom Interior
So I can use the side terminals from here on the positive and negative side posts for the 1/0 guage cable http://www.knukonceptz.com/productDe...fm?prodID=GMBT
and then get regular regular ring terminals with about 15 feet of wire
If im wrong could you please tell me
I just installed mine not long ago. They recommended 4 gauge, so I used a 2 gauge power/ ground. I got those same battery terminals from knukonceptz, but I would recommend getting some thicker ring terminals. Take a look at these:
Yes. You can use the GM side post terminal. Yes. Regular ring terminals are used with it. 15 is far too much wire. You would probably need 5 feet at the most for the positive end. And 1 foot to run from the battery to ground.
If you use a ground terminal (like the one I gave you the link for) there is a hole already in the metal just behind the battery and a flat place next to it. Just sand the paint off the flat area and use a self tapping screw to install the terminal. If you go that route, your ground wire probably won't even be a foot long. I would also recommend using a protective wire loom (available at most parts stores) on the alt-to-battery wire cuz it will get quite hot near the alternator.
2000 3.8L Firebird, Silver Metallic<br /><br />\"Yes, London. You know, fish, chips, cup o\' tea, bad food, worse weather, Mary f***in\' Poppins, London!!\"
\'93 Red 3.4L Camaro<br />Engine: Jet II, Pacesetters, K&N FIPK, Accel Wires, Iridium Plugs, Flowmaster, ASP U/D, 180 Thermo, much more...<br /><br />\'98 Z28 Vert Triple Black A4 Stock for now<br />34000 Miles<br /><br />Not enough room in the sig for my stereo.
Hey thanks for the compliment...lol...As for the big three has anyone done it? I have a 98 base v6 and just got done checking out under the hood. I'm a little confused with the 2 grounds. Stock there is a wire going from the batt neg. to a bolt on the frame about 6 inches away from the battery. Then there is a wire going from the batt neg. to a bolt connected to the engone block. Are these the wires i upgrade? Along with the alternator power of course...
\"a civic is like a tampon...every pussy has one\"
Originally posted by DevinLooney: Stock there is a wire going from the batt neg. to a bolt on the frame about 6 inches away from the battery. Then there is a wire going from the batt neg. to a bolt connected to the engone block. Are these the wires i upgrade? Along with the alternator power of course...
yes they are... question though... do we have to use the spot on the block for the neg-eng wire. im doing the upgrade now and it looks like its gonna b a pain to get that spot all the way down therrrrrreeee.
\"Well, we don\'t care how bad-*** some dude\'s N/A Honda S2000 motor is; if you go up against 900+ pushrod ponies and 750 pounds of earth-shaking torque with a wrong-wheel-drive econobox, you\'re gonna get a fast and furious old-school ***-whipping.\"
I didn't upgrade the one going from the battery to the engine block. I used a 2 gauge alt-to-battery, then added a 2 gauge battery-to-body using a platinum ground terminal and keeping the factory ground, then instead of having to reach all the way down there to upgrade the battery-to-block wire, I added a new 4 gauge wire that runs from the alternator mounting bolt (this works just as well because the alternator housing is metal, which means it is grounded to the block) to the existing ground point on the driver's side. This along with the existing factory ground wire seems to work pretty well.
