Hey guys... I'm relatively new to the stereo stuff and I need some help. Here's the problem. I have to 10" subs w/ a 400 watt amp. The problem is that sometime one of my subs just stops working, and then it'll kick in alil bit later then stop again. I've triple checked all of my connections, the amp is working, it's just the one sub. Now I'm thinking it might be the RCA cables b/c if I switch the l/r around the one sub that's not working will work and the other won't. So... new RCA cables? Also, if I fiddle w/ the connections on the back of the head unit (not stock) it'll kick on. So... any help will be apprieciated... Thanks guys.
Need Help w/ subs
by DongrossmdI’m new. I actually don’t own a Camaro or firebird. I do have a 2000 Camaro 3.8 fly by throttle and 4l60e. This is installed in a 1980 Triumph TR7...11 hours ago
