I want to put a underbody neon kit under my car but i have to put a switch on the inside of my car. To do this i have to put a wire through the firewall.
Wheres the best place to drill?
Are there any holes in the firewall already that i can poke a wire through?
I dont want to drill a hole really.
1995 Camaro 3.4L<br />dynomax super turbo muffler<br />SLP CAI<p>It\'s red so it must be fast!!!
I did see that, but it looks like its down low and i dont want to unbolt the pcm. my friend has jack stands so ill see if i can poke a wire through from underneath the car.
Does anybody know where this hole leads to??
<blockquote>quote:</font><hr>Originally posted by thabomb180: ill see if i can poke a wire through from underneath the car.
Does anybody know where this hole leads to??<hr></blockquote>
Use a wire coat hanger to help feed it through. You have to take off the panel under the glovebox and the long one running the length of the passenger door.
- <a href=\"http://www.thenebula.com/carpics/pics2/camaro2.JPG\" target=\"_blank\">White \'99 V6 Camaro</a> (M5, 3.23s)<br />- 3\" Borla Exaust, RK Sport Induction Lid, Fast Toys Ram Air, K&N Air Filter, !Silencer, !MAF Screen, B&M Short shifter, Manual Fan Switch, 160° Hypertech Powerstat, BMR Boxed LCAs(rubber/poly), BMR STB<br /><a href=\"http://www.cardomain.com/member_pages/view_page.pl?page_id=386884&page=1\" target=\"_blank\">*My Cardomain Website*</a>
this is how i did it when i put fog lights in my car and needed to wire them to a switch in my interior. there's a big thing of wires going inside on the driver's side. right above it is a real small hole that i was able to feed the wires through. hope this helps, the webpage has pics of it http://www.geocities.com/MotorCity/T...foglights.html
behind the pcm is the easiest. it's only 4 bolts to remove the pcm. easy. then you have to remove the passanger kick panel, (two plastic screw-things) and you can see that grommet from there.
<blockquote>quote:</font><hr>Originally posted by awesomeame: behind the pcm is the easiest. it's only 4 bolts to remove the pcm. easy. then you have to remove the passanger kick panel, (two plastic screw-things) and you can see that grommet from there.
Im putting neons on the inside of my car but i took out the cigarette lighter and put a switch there i just pulled up the plastic around there and connected a multi-tap cigar lighter on the inside and hooked everything up there its all hidden i m not sure if you could do that somehow by running it from under the car to there or if it would be enough power but just thought i would share it with you and see if it could help
- Why tiptoe through life to arrive safely at death -
