So my antenna goes all the way up when the stereo turns on but when I turn it off it goess all the way to the bottom but stays up about 4 inches. I can push it in but it wont go in automatically. What could be causing this? What do I need to replace?
Antenna problem
Can you still here the motor running? Trying to pull it down? Or does it just stop running too early? Might be some dirt or sand in there. You can attempt to take it apart if you want, but I don't think the stock GM power antennas are too friendly on that. Don't think the mast unscrews or anything. (Can't remember. Replaced mine with aftermarket 4 years ago)
Yea the motor still trys to pull it down but it wont go down seems a little bent I think1996 Firebird-Y87:SLP Cold Air Intake,Y87 Perf. Package: 3.42 Gears w/ Zexel-Torsen LSD, Sport Steering(14.4:1 ratio), Dual Exit Exhaust,800 watt Pioneer Amp and Two 10\' subs with a custom trunk enclosure.
by DongrossmdI’m new. I actually don’t own a Camaro or firebird. I do have a 2000 Camaro 3.8 fly by throttle and 4l60e. This is installed in a 1980 Triumph TR7...7 hours ago
