Bose Box - FirebirdV6.com/CamaroV6.com Message Board
Bose Box
  • Bose Box
    Ok I have a problem. I have a custom box that hides in the back like the stealth box. Then I bought one of those bose boxes with the 6.5" sub. But It won't fit with the Other box in the way. Is there a way to make it fit. Will it fit with the real stealth box or will I have to make one??
    My Car: 1994 Camaro 3.4 V6 5-Speed<p><a href=\"http://www.cardomain.com/id/speedyman_2\" target=\"_blank\">My Car</a>
    I'm not real familiar with that bose box, but I'll try to help you out. If you bought an aftermarket stealth and a 10" sub, completely foget about using the bose sub. Take it out. If it will separate from the back of the trim panel, pull it out and install your stealth. If there's still too much bose garbage in the way, just go to a salvage yard and get a new trim panel from a normal f-body. :D
