It's amazing how the tiniest rattle can ruin the whole system and that's all you hear. I find that usually the worst offenders are the trim panels on either side of the hatch that are held down by nylon thumb screws. Does anyone have some suggestions on how to secure these pieces?
rattling culprits
rattling culprits
╓<br />║ Matt M<br />║ <a href=\"http://home.austin.rr.com/morrism/3800/sunset_logo2.jpg\" target=\"_blank\">Down with the Sixxness</a> <br />║ Polo Green 1995 3.8 Camaro<br />║ intake, cat, catback, shocks, 3.42\'s, and 12\'s in the trunk<br />╙Tags: None
I had a problem with my 94 Firebird driver's side hatch panel always vibrating and coming loose. I ended up using trim screws to hold it down instead of those cheap nylon push-in fasteners. I found the screws at Autozone which had a very low profile (thin) head and were completely flat on the bottom (not countersunk type screw heads). Though you could see the head of the screw on the outside, it still looked clean and factory.
Another thing that may work would be to apply a layer of either 1/8" or 1/4" foam underneath the plastic panels with high quality spray adhesive. This would help dampen the panel and prevent 'plastic to plastic/matal' contact.2006 Tiburon
Originally posted by 96firebird311:
Are you sure those are the only panels making noise?
[ August 02, 2004, 10:15 PM: Message edited by: user1101 ]╓<br />║ Matt M<br />║ <a href=\"http://home.austin.rr.com/morrism/3800/sunset_logo2.jpg\" target=\"_blank\">Down with the Sixxness</a> <br />║ Polo Green 1995 3.8 Camaro<br />║ intake, cat, catback, shocks, 3.42\'s, and 12\'s in the trunk<br />╙
I lined the joints where those panels meet the front ones with some foam weatherstripping. I also found that the pieces around where seat belts come out will rattle some. And also some of the trim under the hatch lid rattles every once in awhile. But my very worst rattle has been those thumb screws on the passenger panel turn and loosen. And when they do, they rattle like mad.
