voltage cutoff - FirebirdV6.com/CamaroV6.com Message Board
voltage cutoff
  • voltage cutoff
    is there some type of automatic voltage cutoff switch that i could hardwire to my auxillary power items so the battery wouldnt die again? in example a switch that would shut off when my battery reached down to 10 volts.
    I have been looking for the same thing. Neither AutoZone or Radio Shack had anything. They can't be too expensive or hard to wire because most power inverters come with it built in as a feature.
    I tried searching the internet, and I only came up with these:
    http://www.e-insite.net/ecnmag/index...cleid=CA235786
    And you might be able to modify this to work:
    http://www.balakracing.com/autocutoff.htm
    <a href=\"http://www.fatninjas.com/camaro\" target=\"_blank\">\'96 Camaro Convertible</a>
      Crutchfield carries one that lights up, but I don't think it actually cuts off power. Here it is. I think there are some out there that cutoff power..... I'll look around.
      Red 96' A4 Firebird
      Audio Audio and Autotek
      Check it out here!
        with the crutchfiekd thing it wouldnt seem like it would be hard to wire a relay that was always on to the red led positive terminal and when the red led lights up then the relay would engage and disengage the power flow.
        ever mind, that would end up in a continuous circle of problems.
        when the battery would cut off then the led would shut off and then the relay would open up again allowing power through.......damnit :mad: [img]smile.gif[/img]
          Ive seen things before that just tell you the voltage, like something you plug into the cig lighter, which could obviously be hard wired...Ive been wanting the same thing fopr a while too....unfortunatley our cars dont have that feature...most other GM's do.. :mad: ...I saw something before that read cvoltage and was a thermometer...dunno?
          EDIT:
          heres a few things that might help...if your good with electronics
          http://electronicsworld.tripod.com/p...pliesckt4.html
          http://electronicsworld.tripod.com/psimages/4.gif
          http://www.xenotronix.com/products/lvco.htm
          [ June 27, 2003: Message edited by: nikon ]</p>
          05' CTS-V
          00' Camaro - SOLD :(
            well if most other gm;s have that feature then it wouldnt seem like it would be too hard to find the part using a wiring diagram of the car and rip one out of another gm at a junkyard or just order the part.
              <blockquote>quote:</font><hr>Originally posted by nikon:
              EDIT:
              <hr></blockquote>
              We have a voltage meter in the instrument cluster if that's what you're talking about. If you want a more accurate one, you could get an aftermarket gauge by autometer. All you have to do is connect it to power and ground and it'll tell you the voltage.
              I know that someone has to make them, most new amps will actually turn themselves off if they drop below 10V to protect the amp.
              [ June 27, 2003: Message edited by: camaro_speedemon ]</p>
                ignition switch must be on for our volt meter to work, and ya I want something digital...for when the ignition is off, and only accesory power is on....
                05' CTS-V
