is there some type of automatic voltage cutoff switch that i could hardwire to my auxillary power items so the battery wouldnt die again? in example a switch that would shut off when my battery reached down to 10 volts.
voltage cutoff
I have been looking for the same thing. Neither AutoZone or Radio Shack had anything. They can't be too expensive or hard to wire because most power inverters come with it built in as a feature.
I tried searching the internet, and I only came up with these:
http://www.e-insite.net/ecnmag/index...cleid=CA235786
And you might be able to modify this to work:
http://www.balakracing.com/autocutoff.htm<a href=\"http://www.fatninjas.com/camaro\" target=\"_blank\">\'96 Camaro Convertible</a>
Crutchfield carries one that lights up, but I don't think it actually cuts off power. Here it is. I think there are some out there that cutoff power..... I'll look around.
with the crutchfiekd thing it wouldnt seem like it would be hard to wire a relay that was always on to the red led positive terminal and when the red led lights up then the relay would engage and disengage the power flow.
ever mind, that would end up in a continuous circle of problems.
when the battery would cut off then the led would shut off and then the relay would open up again allowing power through.......damnit :mad: [img]smile.gif[/img]
Ive seen things before that just tell you the voltage, like something you plug into the cig lighter, which could obviously be hard wired...Ive been wanting the same thing fopr a while too....unfortunatley our cars dont have that feature...most other GM's do.. :mad: ...I saw something before that read cvoltage and was a thermometer...dunno?
EDIT:
heres a few things that might help...if your good with electronics
http://electronicsworld.tripod.com/p...pliesckt4.html
http://electronicsworld.tripod.com/psimages/4.gif
http://www.xenotronix.com/products/lvco.htm
[ June 27, 2003: Message edited by: nikon ]</p>
05' CTS-V
00' Camaro - SOLD :(
<blockquote>quote:</font><hr>Originally posted by nikon:
EDIT:
[ June 27, 2003: Message edited by: nikon ]<hr></blockquote>
We have a voltage meter in the instrument cluster if that's what you're talking about. If you want a more accurate one, you could get an aftermarket gauge by autometer. All you have to do is connect it to power and ground and it'll tell you the voltage.
I know that someone has to make them, most new amps will actually turn themselves off if they drop below 10V to protect the amp.
[ June 27, 2003: Message edited by: camaro_speedemon ]</p><a href=\"http://pics.projectpredator.com/thumbnails.php?album=16\" target=\"_blank\">2003 Zinc Yellow Mustang GT</a> 1 of 701<br />ET : TBD<br />But our shenanigans are cheeky and fun! Yeah, and his shenanigans are cruel and tragic. Which... makes t
ignition switch must be on for our volt meter to work, and ya I want something digital...for when the ignition is off, and only accesory power is on....
05' CTS-V
