i know its been discussed to death but im not really the expert when it comes to wiring....i have a 94 and i am planning on using the one write up on cardomain...but he has a 3.8 are all the wiring and connections the same for a 3.4?
thanks alot
no the wirings arent the same, i forgot what color your suppose to tap into i think its a green one instead of the blue one but definately dont hold me to that.
i know thats the basic idea but like i said i dont know much baout wiring id fell alot more confident if there was a 3.4 write up someone could give me
Originally posted by FlamespikeMST1: why not just tap into where the fan plug goes, connect it to some power , ground it to a switch
I think that sets off the SES...
I honestly think its the same for a obdI or obdII cars except on obdII its a good idea to use resistors.
