Hey All, First time on the site, This rocks, I've a 97 V6 camaro, everything stock, put a sony MP3 CD unit in for a head and just bought new speakers to replace the stock ones. I put 6X9 in the back which took a little cutting but no problems. 6.5 in the midrange and my front speakers have 4 wires going to them, I beleive these are run in parallel, How do I replace this and what type of speaker should I put in the door.
Front Speakers
Welcome to the site.
If your Camaro has 4-speaker wires in each of the doors, it probably has a factory premium sound system known as the Bose or Monsoon sound system. 2-speaker wires power the tweeter and the other 2-speaker wires power the woofer. According to this website's Modification Encyclopedia the tweeters in the doors are 4-OHMS, which are powered from the factory head unit and the oversized 6-1/2" (actually 6-3/4")woofers in the doors are 2-OHMS, which are powered off the Bose/Monsoon amp. If you try to power your new door speakers off the factory amp, you're going to run into an OHMS issue since your new speakers will be 4-OHM while the factory amp is set up for 2-Ohms for that particular location. I would leave the factory wiring alone and run new speaker wire to the doors and power your new speakers off your new CD-Player OR install an aftermarket amp.
[ August 12, 2004, 01:23 PM: Message edited by: nda0602v6 ]2006 Tiburon
Originally posted by nda0602v6:
I would leave the factory wiring alone and run new speaker wire to the doors and power your new speakers off your new CD-Player OR install an aftermarket amp.╓<br />║ Matt M<br />║ <a href=\"http://home.austin.rr.com/morrism/3800/sunset_logo2.jpg\" target=\"_blank\">Down with the Sixxness</a> <br />║ Polo Green 1995 3.8 Camaro<br />║ intake, cat, catback, shocks, 3.42\'s, and 12\'s in the trunk<br />╙
by DoodlerHi, everyone. We bought a 97 base model convertible Camaro and someone broke the motor ... Lights were blinking on the dash and that someone ignored the...2 hours ago
by ssms5411Still trying to find oil leak on my Camaro, it’s a tough one. I think it is the oil pressure sender myself. Leaking when raving and going into boost....4 days ago
