I have LED bulbs and you told me that EL-12 unit would fix it. Well, i got it from autozone for $8, but it didn't do anything
Dominic.........
Are your flasher bulbs lighting? If not theyre in backwards [img]smile.gif[/img] Everyone on the forum (ls1.com) runs the EL12.
I will be trying this same thing this weekend, and I'll let you know what happens to me.
[ June 30, 2003: Message edited by: Dominic ]</p>2002 5-spd NBM Camaro
Details: www.1lev6.com
yeah, they light up, but i have to manualyflick them to make it flash which gets very annoying. i got the EL-12 and took out the panel under the steering wheel and poped out the thermal one and put it in the el-12, but it didn't do anything<a href=\"http://www.xbox3604free.com/default.aspx?r=381546\" target=\"_blank\">http://www.xbox3604free.com/default.aspx?r=381546</a>
Well there are two flashers. One is for hazards and one is for regular blinkers. Did you switch the right one?2002 5-spd NBM Camaro
Ok, you were right, i was changing the hazards [img]graemlins/dunce.gif[/img] . But damn, i noticed that the mechanics did a piss poor job of putting everything back together. The damn flasher was WAY in the very back of the steering column. Then after I replaced it and put it back where it should be, the bolts wouldn't line up on the kick panel :mad: . Ah!
But, good news........ EL-12 worked perfect!!
Thanks Dominic
[ June 30, 2003: Message edited by: AcidDrag0n ]
[ June 30, 2003: Message edited by: AcidDrag0n ]</p><a href=\"http://www.xbox3604free.com/default.aspx?r=381546\" target=\"_blank\">http://www.xbox3604free.com/default.aspx?r=381546</a>
you're welcome
you might want to spend another $8 and buy one for the hazards so that those still work too, just in case :D2002 5-spd NBM Camaro
by ssms5411Just ordered some Toyo 315/35/17 tires for my 17x11 rims. Hopefully I can get them on the beginning of next year. Will post pics.1 hour ago
by ssms5411Haven’t done anything on the Camaro, but put LEDs on my truck headlights . And my oil pressure sensor went out on the truck so going to fix that this...1 week ago
