I had to change my left side door.after I hooked up all the wires inside the door.the radio will power on but no sound at all.not from the radio or the cd player.I already tried 3 other radios but its the same.anyone knows whats wrong before I take it to the dealer :mad:
No sound
Only other thing I could suggest is to take the door panel off and check the speaker wires. If two speaker wires are touching each other, the headunit may have a protection feature built in which would cut the output power to everything. Do you have the Bose or Monsoon system? Also, what kind of car, Camaro or Firebird? Year?
I wouldn't take it to a dealer because from what I've personally experienced, (not all) but a majority of them are hacks. If everything was working good till you messed with the door then that's more than likely where the problem is. Even before removing the door panel, remove the lower kick panel to access the wires that lead to the door. There should be plugs in that area, unplug the 'speaker' wires and see if you get sound from your other speakers. If it works then the problem is between the kick panel area and the door.2006 Tiburon
I had this happen to me a few weeks ago. If your fuses are fine, then it's almost definitely a short. Disassemble the doors, check out your wires and secure them so that they're not shorting out at any of the exposed connections.
As you reassemble, keep testing the radio after each step to make sure it's still working.
It sucks, but it's a cheap fix.╓<br />║ Matt M<br />║ <a href=\"http://home.austin.rr.com/morrism/3800/sunset_logo2.jpg\" target=\"_blank\">Down with the Sixxness</a> <br />║ Polo Green 1995 3.8 Camaro<br />║ intake, cat, catback, shocks, 3.42\'s, and 12\'s in the trunk<br />╙
If your Camaro has the Bose/Monsoon system, check the 'factory amp' to see if it's getting power. (remove the spare tire to access the amp) On the plug that plugs into the amp, use a test light or volt meter to see if the 2 Orange wires have power. Both of them should be hot. Here's a description of what wire does what coming out of the amp.
Pin Wire Color Circuit Number Function
E1 Dark Green 117 Right Front input -
E2 Grey 118 Left Front input -
E3 Tan 201 Left Front input +
E4 Dark Black 46 Right Rear input +
E5 Light Blue 115 Right Rear input -
E6 Yellow 116 Left Rear input -
E7 Brown 199 Left Rear input +
E8 Black 650 Ground
E9 Black 650 Ground
E10 Unused Unused Unused
E11 Orange 1040 Fused battery feed
E12 Orange 1040 Fused battery feed
E13 Black 1856 Left Subwoofer +
E14 Yellow 1956 Left Subwoofer -
E15 Dark Blue 1857 Left Front speaker +
E16 Light Blue 1957 Left Front speaker -
F1 Light Green 200 Right Front input +
F2 Light Green 1852 Right Subwoofer +
F3 Purple 1952 Right Subwoofer -
F4 Light Blue / Black 315 Right Subwoofer -
F5 Dark Green 1795 Right Subwoofer +
F6 Dark Green 1953 Right Front speaker -
F7 Orange 1853 Right Front speaker +
F8 Unused Unused Unused
F9 Unused Unused Unused
F10 Light Green / Black 1794 Left Subwoofer -
F11 Dark Blue / White 346 Left Subwoofer +
F12 Unused Unused Unused
F13 Red 1955 Right Rear speaker -
F14 Tan 1855 Right Rear speaker +
F15 Tan 1859 Left Rear speaker +
F16 White 1959 Left Rear speaker -2006 Tiburon
