k fellas check this out... i ripped out all BOSE speakers out of my 95 camaro... it was soo much trouble to get the damn amp and 2 12's in the back working, my audio buddy had to cut wires and make an RCA adaptor thingy, we succeded and got the amp in and subs along with Pioneer compent system.... NOW, my new Kenwood head unit wont WORK with the setup, what do i need? an ADAPTOR..all new rewiring?? THANKS
BOSE...what was GM thinking??? HELP!
Sounds like you guys hacked that stereo up pretty good. Why would you make an RCA Adaptor, if your head unit was made in the last 10 years, you should have RCA preouts on it. Just run a 14' rca cable from the front to back, then your subs will work just fine with alot less distortion than trying to run it off of regular wires and changing it to an RCA jack. As far as the compontents, are you sure they are hooked up right? Something very simple is probably just being overlooked, make sure all positives go to positive and negatives to negatives. I have the Bose system in my 95 Camaro, but I never felt the need to upgrade it, so mine's stock. You might wanna check with the guys a little more knowledgeable than I, since there may be an OHM difference involved, 8 ohms seems to come to mind for some reason. Well... ya got one solution [img]smile.gif[/img]<a href=\"http://www.fullthrottlev6.com\" target=\"_blank\">www.fullthrottlev6.com</a><br /><a href=\"http://www.chitownracing.com\" target=\"_blank\">www.chitownracing.com</a>
