Hi. can i use this (SShevy) wiring diagram to my 93 firebird? and example this: Door Unlock - Orange/Black (-) BCM. is that mean that i have to plug orange/black wire to - ?
thanx for helping.
Wiring diagram for alarm install (SShevy)
12 volt - Red*
Starter - Yellow*
Ignition - Pink*
Acc (heater blower)- Orange*
Acc - Brown*
* heavy gauges wires in ignition switch harness located under the dash by the steering column
Passlock wires - 2 small guage wires in oranging sheathing near ignition harness
Brake wire - Light Blue(+) - at brake switch or wire harness running by the door sill
Reverse wire - light green wire (+) in white harness in passenger kickpanel)
Tach - white wire in lower harness of PCM. Pin 35 for 98 and Pin 10 for 99-up
Trunk release - Black/white at switch
Headlights - Yellow(+) - at headlight switch
Parking lights - Brown(+) - at headlight switch
Horn - black(-) - steering column harness
VSS (vehicle speed sense wire) - Green/white - Radio harness on camaros...at cruise control module on Firebirds. (normally used for navigation systems)
Factory arm - (+) - Gray at BCM
Factory disarm - (+) - Tan at BCM
Door Lock - Red/black (-) at BCM
Door/Trunk trigger - White (-) at BCM
**You'll have to wire the alarm for domelight supervision so that the BCM "wakes" back up**
Drivers window up - Blue*
Drivers window down - Brown*
Passenger window up - Light Blue*
Passenger window down - Tan*
*located in the drivers door
PCM is the computer in the engine compartment near the windshield on the passenger side.
BCM is located in the passenger kickpanel.
thanx for helping.
12 volt - Red*
Starter - Yellow*
Ignition - Pink*
Acc - Brown*
