ok, i have the stock car alarm on my camaro. its worked fine ever since i got the car. lately however, when i press the lock button on the remote..the doors lock, the horn chirps twice, and then about 3 or 4 seconds later the alarm starts going off on its own. it doest this every time. anybody got a clue?
my alarms gone crazy
Try adjusting the sensitivity of the alarm via the shock sensor. It is located over the right rear wheelhouse near the spare tire in the hatch area. To adjust, remove the label covering the adjustment knob and adjust as desired. Turn to the right (clockwise) to increase sensitivity and turn to the left (counterclockwise) to decrease sensitivity.
2000 Pewter Pontiac Transam 360rwhp, 370ftlbs
1998 Sport Gold Metallic Chevrolet Camaro *SOLD*
1974 Silver Chevrolet BIG BLOCK Corvette
thought about that, but its weird though...
i havent adjusted the sensitivity since ive owned the car and it has just now started this. started about a week ago....\"....let freedom ring with the shotgun blast.\"<br /> <a href=\"http://www.cardomain.com/memberpage/511684\" target=\"_blank\">http://www.cardomain.com/memberpage/511684</a>
ok, played with the sensitivity...turned it all the way down. problem still exists...
any other ideas anybody??\"....let freedom ring with the shotgun blast.\"<br /> <a href=\"http://www.cardomain.com/memberpage/511684\" target=\"_blank\">http://www.cardomain.com/memberpage/511684</a>
Yeah, it's the shock sensor gone bad. Has it rained a lot or have you cleaned your fenderwell? On ls1tech.com there are tons of posts about this problem. Whenever you clean the fenderwell or if it rains a lot this is a common problem. It happened to me last year. I unplugged the shock sensor and it worked fine, then when the weather dried up I plugged it back in and it has been fine ever since. Give that a shot...and when you unplug it, see if it's moist in that area.1999 Y87 Camaro<br />Whisper Lid, SLP SS Takeoff Exhaust
