new amp setup!!! 3 in spare tire area - FirebirdV6.com/CamaroV6.com Message Board
  • new amp setup!!! 3 in spare tire area
    ok guys this is what i am doing, i am putting 3 amps in were my spare tire is supposed to be but i have a few questions, first b4 u freak yes it will fit i am going to stagger 2 and one is going to go were the monsoon amp went!! my question is though can u ground 2 amps to one ground? also my rca question in my other post how can i manage to set this all up with 3 amps in one spot!! and however can ur ground go until it is too far?
    there are distribution blocks for Ground and power wires so you have one input and however many out. Also for the RCAs, you may want to think about getting an audio processor. It'll act as an equalizer to clean up the signal from the RCA coming from your head unit. This unit will also provide you with several more outputs.
      hey i knwo a good bit about stereo but i dunno too much bout them to things is there anyway u could send me in the right direction?
        http://www.crutchfield.com/S-6daQ2VU...roup.asp?g=715
        pick one based on the guage you need. If you need a 8 guage going to your amps, you may want to run a 4 guage to the distribution block.
          then a processor with however many outputs you need:
          http://www.crutchfield.com/S-6daQ2VU...rch=processors
          This is the best way to run multiple amps. However there are much cheaper ways. Y-connectors like you said are one way. However signal is lost when you do that. I guess it all depends on how much money you have versus how clear you want the sound.
