how to stop rattles? - FirebirdV6.com/CamaroV6.com Message Board
  • how to stop rattles?
    has anyone else had a big problem with their trunk rattling? mine rattles like crazy. any suggestions of where the best places to put dynamat or anything else would be helpful.
    1997 Camaro<br />17x9 Chrome SS wheels, SLP CAI, Magnaflow Catback,<br />High Flow Cat, Blacked out Lights, 20% tint, AUDIO: 1600W Kenwood eXcelon Amp, 12\" Kicker L7, 1 Farad Cap (Recently STOLEN),<br />H&R Springs and KYB AGX\'s,<br />Billet Grille
    My WHOLE car is sound deadened and my hatch still rattles. What tends to rattle a lot is the actual wing and the panel in the back where it says CAMARO.
    IF you can tighten upyour wing and that panel it will cut down the rattles.
    What im going to do tomorrow is get some of that foam stuff that comes in the can and im going to fill up the whole inside of my hatch with it that way it will stiffen up and rattle less.
      yea i was thinkin about getting that stuff, its called poly fill i think. it was recommended to fill my sub box 50% with it.
        Polyfill very similar to the stuffing in a pillow. Camarowidbass is refering to expanding foam. Two completely different things. Caution should be exercised when using expandable foam. Once it starts expanding NOTHING is going to stop it. It will blow those plastic pop rivets right out if you use too much. Also, try not to get it anywhere visable. Where ever this stuff goes, it's there to stay.
        Red 96' A4 Firebird
        Audio Audio and Autotek
        Check it out here!
          i was thinking about using dynamat and stuffing some inside panels with polyfill to help absorb the sound, would this work?
            poly fill NOT stop rattles, you use poly fill to fool the sub into thinking its in a bigger box, but thats about it.
              I used expandable foam to fill all the space in the hatch....that eliminated all the rattles I had.
                how did u go about doing that?
                  im guessing he took off that panel and just sprayed it in there.
                  • Manimal
                    Coil springs
                    by Manimal
                    4 days ago
                  • Manimal
                    Newby here
                    by Manimal
