Help with my stereo please! - FirebirdV6.com/CamaroV6.com Message Board
  • Help with my stereo please!
    I have a JVC mp3 cd player and a infinity woofer and it was working last night, but this morning the CD player got no power (power off) everything else was fine (Horn, HVAC, Window...) I checked the fuse and they seem to be ok. What could it be????
    Thank you!
    TECHNOBETSY
    Most likely the power wire that is hooked up to the cd player came loose. Take out the cd player and check the wires.
    \"Well, we don\'t care how bad-*** some dude\'s N/A Honda S2000 motor is; if you go up against 900+ pushrod ponies and 750 pounds of earth-shaking torque with a wrong-wheel-drive econobox, you\'re gonna get a fast and furious old-school ***-whipping.\"
      you know what, my factory keyless remote won't work either I have to use key to open the door, trunk release button under the dash didn't work either... any idea?
      TECHNOBETSY
        If other things aren't working then it may just be a fuse. Go back and double check every single fuse.
        I once had problems with something not working and it turned out to be a blown fuse that was completely unrelated to what wasn't working.
        2006 Tiburon
          Thanks man, I did check all of the fuses, turned out to be the COURTSY fuse was blown... the weirdest thing is that it blew right after I changed it... I wasted 3 brand new 15A fuses... what else can I do??
          TECHNOBETSY
            About 2 years ago i had a similiar problem where i kept going through fuses. It turned out my remote wire to my sub was exposed a bit and touching some metal. Based on that knowledge, check all your wires.
            Eclipse 8443, CDT ES-620s in doors (Clarion APX401.2), IEK, CDT 6X in rear(HU), Image Dynamics ID10v.3D.4 in stealthbox(Clarion DPX1001.2)<br /><a href=\"http://www.sounddomain.com/id/larryfirebird33\" target=\"_blank\">http://www.sounddomain.com/id/larryfirebird33</a><br />borla cat-back, FTRA, whisper lid
