Have I got an external amp??? - FirebirdV6.com/CamaroV6.com Message Board
  • Have I got an external amp???
    I want to replace my AC Delco headunit with something nicer,but I'm not sure if it's got any external amps on it????
    If it has how would that effect replacing the HU??
    My car is a '98 Camaro,and any help would be very useful!!
    Thanks in advance,
    Steve
    do u have the monsoon system thats the only way u could have an external amp and its not hard all u need is a mounting kit and a antenna adapter.
      How would I be able to tell if it's a Monsoon system?
        It says Monsoon on the head unit and it has 8 speakers..
        Derek <br /><a href=\"http://www.cardomain.com/id/dmiller_2005\" target=\"_blank\">2002 Metallic Silver Camaro</a><br />35th Anniversary
          IT IS POSSIBLE YOU HAVE A MONSOON SYSTEM EVEN IF YOUR HEAD UNIT DOES NOT SAY "MONSOON"
          '97 and early '98 model Camaro's Monsoon head units simply said "Delco Electronics" just like the non-Monsoon systems. Check your door codes to find out if you have the Monsoon system:
          ULO = Monsoon Cassette HU
          UNO = Monsoon CD HU
          U1S = 12 disc changer
          But regardless, you can replace the head unit if you have the monsoon system or not. Just as you would with any other car. If your aftermarket head unit is single din, then you'll need a dash kit, wiring harness and antenna adapter. If it's din 1/2 omit the dash kit.
          Red 96' A4 Firebird
          Audio Audio and Autotek
          Check it out here!
