Ok, I have two 12" mtx subs and a kenwood 600w amp, they have been working great untill recently, all of a suden they just stoped working and won work at all, i chacked to see if they where blown but they wernt, and the amp is in good condition too, but sumtimes the subs will turn back on with out touching a thing, it really frustating me now cuz i have tryed but dont know what is wrong, i think it migh be a short of some kin but im not sure, does anyone have any ideas of whats causing this and how to fix it?? any advise will be appreiated [img]smile.gif[/img]
why arnt my subs working ??
Mine did the same thing....it turned out being one of the subs shorted out and ended up burning the amp. id say pull the power and have the speakers check out by a GOOD stereo shop.If it were me i wouldnt even TRY and run the subs or the amp..but thats just me.2001 Black S10 Xtreme 4.3L A4<br />*RedLineVSix*<br />\"Throwin sparks, draggin frame\"
Check for any loose wires. Maybe power, ground, or remote.
Check them on the amp and on the HU.
Your power wire is fused, right?
[ February 28, 2002: Message edited by: massivefirebird ]</p>Massivefirebird\'s <a href=\"http://www.cardomain.com/id/leondb\" target=\"_blank\">(leonDB) Cardomain</a><br /><a href=\"http://www.flowmastermufflers.com/cgi-bin/flowmaster\" target=\"_blank\"> Flowmaster 80</a>, <a href=\"http://www.knfilters.com/\" target=\"_blank\"> K&N FIPK</a>, <a href=\"http://www.jetchip.com/\" target=\"_blank\"> Jet Stage 2 & 180º T/S</a>, <a href=\"http://www.boschusa.com/AutoParts/SparkPlugs/PlatinumPlus4/\" target=\"_blank\"> Bosch quads</a>, <a href=\"http://www.pilotautomotive.com/pilot2dn.htm\" target=\"_blank\"> Pilot 1055 Fogs</a>, <a href=\"http://makotoautotrends.com/\" target=\"_blank\">Clear turn signals</a>, <a href=\"http://www.autoventshade.com/\" target=\"_blank\">AVS rear blackouts</a>... <a href=\"http://www.massiveaudio.com\" target=\"_blank\">2 Massive CW 12\'s</a>, <a href=\"http://www.kicker.com\" target=\"_blank\">Kicker 2252, 652,& 352 XI Amps</a>, <a href=\"http://www.mbquart.com/2003/en_US/home/\" target=\"_blank\">MB Quart</a>.
did you do the obvious and check the connections for the speakers inside of the box? Sometimes they can rattle loose.
What ohm value are the subs? How do you have them wired?
Perhaps you either have burnt voice coils on the subs. Loose connections on the wires on the subs.
Or you have a bad power supply on the amp caused by wiring the subs incorrectly for what the amp can handle.
Test the amp on other speakers to see if it causes the same problem. Do the subs work at first and then stop working? Symptom of the amp getting to hot due to being wired incorrectly and it is shutting it self off.
Well give me some more details and ill try to point you in the right direction
