*Amp Installation Complete* - FirebirdV6.com/CamaroV6.com Message Board
  • *Amp Installation Complete*
    Thats right it finally done and all of it works correctly(knock on wood)... i ran up to best buy to get a battery terminal they only had one brand(rf) 8.99...bs... anyway brought it back to install it and it worked for 5mim then i started to play w/the bass boost on the amp... then the bass stoped. i checke all the fuses they were good so we pulled out the HU and 2 wires form the LOC were loose from the wires had to tap into so we fixed it... next on my list is DYNAMAT i neeed it badly... inside this things pounds like a mofo i have the mtx thundeform and im runnin 350w to it(it could only handle 250 rms)on the other hand it rattles like a mofo on the outside so im gonna need some dynamat... i cant believ how good it sounds from inside im also gonna put a swicth in the remote turn on wire so i could shut it down if my dad needs to use the car... thankz all u guyz for the help and thanks alot to 96firebird311 u the phuckin master... and again thankz alot and im gonna be back w/qs when mounting my amp so see u soon...
    turn your bass boost down. You shouldnt be using more than 2 or 3 db.
      <blockquote>quote:</font><hr>Originally posted by camarozrule:
      thanks alot to 96firebird311 u the phuckin master<hr></blockquote>
      No problem man! We're here to help! [img]smile.gif[/img]
      But think again on that dynomat purchase. #1= There are MANY knock off brands that are just as good but 1/2 the price. I use ramMatt. #2= Dynomat is a "sound dampener". It's meant to keep road noise to a reasonable level. Not to prevent rattles. You best bet is to seek out exactly what pieces are rattling and then wedge something in in there so they cannot move. THIS is how you cure rattles. Not only will you be happy with the results, your pocket book will thank you!
      :D
      Red 96' A4 Firebird
      Audio Audio and Autotek
      Check it out here!
