I have a few lights out in the front (one of each, on either side). I have done a search and have found several people saying they just "reached in". I have tried from every angle I can think of, and I can’t even get close.
Just from looking at it, I don’t see an easy way of getting to it, well, with out removing half the engine.
I'm pretty sure it's different for 97's, but I have a 2001 and the easiest way to get to the turn signal markers/corners is by taking the headlight out.
However, I'm not sure that is the case with a 93-97, due to the headlights being different. I've heard that it is manageable to go from the bottom of the car and take off the plastic flap(held by a screw or bolt) and then going from there. If attempting this method, it seems like it would help if the front of the car was up in the air.
Yes, I know \"Artic\" should be spelled \"Arctic\". Can any of the mods change this?
Hey.. on the drivers side, under the hood you can get to the turn signals from behind it.
The just take a screw driver and unscrew the air tube off of the air box. and the air box slides upward , leaving a large hole straight down..
stick your arm in there and the light socket is right there.
On the passengers side i think its the same thing, i really cant remember though but you may have to remove the battery to access it but good luck.
4 days ago
