Is it possible to change my monsoon headunit and replace it with my alpine cda-9813? It seems kinda impossible cuz the alpine has output for 4 speakers while monsoon is 8 speakers.i also know that monsoon headunit powers front tweeters while other speakers are powered by amp. it's just all confusing. is it possible? if yes, what do i need to buy?thnaks.
monsoon to alpine....
yes it is possible, just buy the standard harness, antena adapter, and mounting plate and you should be good to go. Dont expect a real change in sq or power output or anything though, you still have the same crappy amp and speakers so it will sound pretty much the same.2001 Arctic White Firebird With Black Drop Top<br /><br />3:42 Gears<br />Zexel LSD<br />BMR upper A-Arms<br />Trans Am exhaust with 3\" I-pipe and cutout<br />Modified intake<br />Mecham Hood<br />Trans Go shift kit<br />Making rear control arms and panhard
T-Punk is correct. Hooking up the Alpine will be a snap...just buy what he mentioned. In terms of sound quality, the Monsoon Amp is doomed right from the start since it receives its inputs from a headunit's hi-level/speaker level outputs. Not to mention the "quality" of the Monsoon Amp itself is far from great, it distorts very easily. Replacing the stock headunit though is still a great starting point. Enjoy2006 Tiburon
