I am want to purchase this part to connect my ipod and I wanted to see if anyone has used it on a 98 or older bird. I searched and could not find a clear cut answer.
GM9- AUX In a 98 Bird
98 3.8 y87 chameleon green bird. Polished Eagle 077\'s. Raised Air box (is that even considered a mod?), lots of maguires gold class(thats not either). My car <a href=\"http://http://briefcase.yahoo.com/bc/wakeb0rdr/lst?.dir=/Car+Pics&.view=l\" target=\"_blank\">http://http://briefcase.yahoo.com/bc/wakeb0rdr/lst?.dir=/Car+Pics&.view=l</a>Tags: None
anyone??98 3.8 y87 chameleon green bird. Polished Eagle 077\'s. Raised Air box (is that even considered a mod?), lots of maguires gold class(thats not either). My car <a href=\"http://http://briefcase.yahoo.com/bc/wakeb0rdr/lst?.dir=/Car+Pics&.view=l\" target=\"_blank\">http://http://briefcase.yahoo.com/bc/wakeb0rdr/lst?.dir=/Car+Pics&.view=l</a>
Do you have the Monsoon system or a cassette player? Probably the best way to know for sure if you can hook up a GM9-AUX would be to pull your headunit out and see if it has the cd-changer jack on the back. It looks like this:
2006 Tiburon
Good call I might as well check for myself. I have the monsoon so I am pretty sure I have the cd changer jack. Any tips on removing the stereo? Just take off the plastic outer and it should pull out hopefully.98 3.8 y87 chameleon green bird. Polished Eagle 077\'s. Raised Air box (is that even considered a mod?), lots of maguires gold class(thats not either). My car <a href=\"http://http://briefcase.yahoo.com/bc/wakeb0rdr/lst?.dir=/Car+Pics&.view=l\" target=\"_blank\">http://http://briefcase.yahoo.com/bc/wakeb0rdr/lst?.dir=/Car+Pics&.view=l</a>
Ok I checked and it has that jack but there are wires in it. Is this just the prewiring for the cd changer that I do not have?98 3.8 y87 chameleon green bird. Polished Eagle 077\'s. Raised Air box (is that even considered a mod?), lots of maguires gold class(thats not either). My car <a href=\"http://http://briefcase.yahoo.com/bc/wakeb0rdr/lst?.dir=/Car+Pics&.view=l\" target=\"_blank\">http://http://briefcase.yahoo.com/bc/wakeb0rdr/lst?.dir=/Car+Pics&.view=l</a>
Originally posted by cobain:
Ok I checked and it has that jack but there are wires in it. Is this just the prewiring for the cd changer that I do not have?2006 Tiburon
I have a monsoon casette radio in my 2K camaro
I bought this unit: {It works great}
Motors Aux. Input Adapter
Product ID: GM10-AUX
Manufacturer: P.I.E
Sale Price $99.95 $63.98
(Savings: $35.97)
Order Options:
Qty:
Category: Accessories
Precision Interface
Description: The GM10-AUX will convert the CD Changer port of select 1995-2004 GM vehicles into an auxiliary input. With this adapter installed you can connect any audio device [ iPod™, DVD, XM Radio (Pioneer GEX-P910XM, Sony DRN-XM01R, DRN-XM01C), Walkman, X-BOX, Playstation, etc] to the factory radio without using FM Modulation. This plug-n-play solution surpasses FM modulation which is the current method of introducing audio in these systems. The GM10-AUX plugs into the factory pre-run 10-PIN cable in trunk, hatch or center console.
If your GM vehicle is listed in our "Order Options" drop-down list but not prewired, an OEM Cable harness must be purchased a GM dealer.
Cable part numbers are:
† Buick /Oldsmobile -------Part # 12344003 if not prewired
? Cadillac Catera---------- Part # 12484910 if not prewired
? Saturn-------------------- Part # 21023550 and Part # 2102353 if not prewired
? Corvette requires PIE Part # COR-HAR if not prewired
Special Notes:
1. The GM10-AUX is not compatible with vehicles equipped with in-dash 6 disc slave units.
2. 1995 -99 AM/FM/CD radios are not CD changer capable, and therefore not compatible with the GM10-AUX.
3. 2000 and earlier models are NOT capable of controlling two units (slave single CD or cassette Deck), therefore, these radios will need to have the slave unit disconnected.
4. Not compatible with GM OnStar™.
Easy plug-n-play Installation diagram available here ! and our application guide is available here !
To Help Complete Your Install, May We Suggest:
Product Name: GM12/PC-PIOX 2000-04 GM To Pioneer Changer/XM Radio Interface
Product ID: GM12/PC-PIOX
Sale Price: $129.99 $84.98
Product Name: GM12-AUXv2 2000-05 GM "Class-II RDS" Auxiliary Input Adapter
Product ID: GM12-AUX
Sale Price: $79.99 $65.98
Product Name: GM9-AUX PIE GM9-AUX 1995-04 General Motors Auxiliary Input Adapter
Product ID: GM9-AUX
Sale Price: $99.95 $63.98
Product Name: RCA6MM 3.5mm to RCA Adapter Cable (by PIE)
Product ID: RCA6MM
Sale Price: $15.99 $10.98
Home
Shopping Cart
Advanced Search
Search
Sign In
Search:
Shopping Cart:
0 Items In Cart
Total: $0.00
Home | Customer Service | Terms and Conditions |Phil
