i know this isn't an f-body question... but i need some help installing a cd player in a 95 aurora... if anyone is familliar with this please email me... thanks
oldsmobile cd player
that has the standard 2 din radio, i beleive. to set it up you need to go get a plastic mounting plate so you can fit in a one din radio, you then need to go to some place like best buy or circuit city and tell them you need a wiring harness and maybe an antenna adapter for whatever brand HU you get to the Oldsmobile Aroura. then you just need to put it all together, unless there is something weird about that car it should be a pretty standard install.2001 Arctic White Firebird With Black Drop Top<br /><br />3:42 Gears<br />Zexel LSD<br />BMR upper A-Arms<br />Trans Am exhaust with 3\" I-pipe and cutout<br />Modified intake<br />Mecham Hood<br />Trans Go shift kit<br />Making rear control arms and panhard
actually i'm just putting the same kind of cass/cd in it.. the one in it now doesn't work anymore... i just don't know how to go about taking the old one out...02 camaro \"silver bullet\" slp CAI, flowmaster american thunder catback, custom 35 anniversary brake light, custom bowtie side markers, custom painted bowtie tailight covers,12 disc cd changer, 18\" replica z06 wheels..
there are a few ways you may have to do this. there will either be a plastic peice around the radio that can just be pulled out, or you may need to remove part of the dash to get it out. if you have to remove the dash, look for several hex head screws (bout half inch socket) and take out what you think you will need to get the peice around the radio out. there may also be a screw in the back of the radio holding it in (for this you will need to just reach around till you find it and then try to remove with a socket or something. other than that i cant think of anything.2001 Arctic White Firebird With Black Drop Top<br /><br />3:42 Gears<br />Zexel LSD<br />BMR upper A-Arms<br />Trans Am exhaust with 3\" I-pipe and cutout<br />Modified intake<br />Mecham Hood<br />Trans Go shift kit<br />Making rear control arms and panhard
