jet performance has a power chip module for like $320, i was wondering if anyone has this and if it's worth it.
power chip question
Yes, the Jet Stage2 module will add 10-15 rwhp, depending on other mods. You will need a 160° or 180° thermostat and always use 92+ octane gas.1994 Firebird 3.4<br />15.65 @ 86.8<br /><a href=\"http://www.funkz.net/firebird.htm\" target=\"_blank\">funkz.net/firebird</a><br /><a href=\"http://mywebpages.comcast.net/funkz/timeslips.htm\" target=\"_blank\">Timeslips</a>
Just noticed your sig, are you sure you need a module for that S-10? There is probably a replacement chip for your truck which costs significantly less than a module.1994 Firebird 3.4<br />15.65 @ 86.8<br /><a href=\"http://www.funkz.net/firebird.htm\" target=\"_blank\">funkz.net/firebird</a><br /><a href=\"http://mywebpages.comcast.net/funkz/timeslips.htm\" target=\"_blank\">Timeslips</a>
well my s-10 had the 2.8 w/carb, i put the 3.4 in and changed it to carb cause i didn't have time to mess with the computer stuff, but now i have time so i'm gonna put the fuel injection stuff on. so all the computer stuff will be the same as the camaro's with the 3.41985 S-10 w/ 3.4 engine, edelbrock intake manifold w/ 4barrel 500 cfm carb, k&n air cleaner, single glass pack Y\'s into 2-2 foot 3.5\" \"boom tubes\"...very loud
