Ok... Whats the difference between the following sub wiring:
Parallel to Parallel
Series to Parallel or
series to series
Which of these 3 are the best for wiring subs? My subs are capible of 3.5ohm and my amps can go 2ohm stable.
According to the Audiobahn website, there is no difference in wiring, when you wire parallel to parallel for both 2ohm and 4ohm (both are exactly the same wiring).
Currently I have the amps wired at 4ohm (2ohm> ;) at Parallel to Parallel.
series to series
