hidden amp - FirebirdV6.com/CamaroV6.com Message Board
hidden amp
  • hidden amp
    I'm looking for a nice hidden place to mount my sub amp to. I don't want it in plain site. I was thinking about mounting it under the front seat or something. or maybe the place where the stock monsoon amp is but on the driver side rear wheel well. does any1 else hav any ideas?
    Britney Spears is the HOTTest girl in the world!<br /><br />2000 Camaro 3.8L Y87<br />Flowmaster 80 American Thunder catback<br />Magnaflow Carsound Catalytic Converter<br />SLP Ram Air Cold Air Intake<br />Whisper Lid<br /> <a href=\"http://www.cardomain.com/id/freestylin59\" target=\"_blank\">http://www.cardomain.com/id/freestylin59</a>
    Did you even look at the other topics?
    http://www.camarov6.com/ubb/ultimate...;f=12;t=003033
    Red 96' A4 Firebird
    Audio Audio and Autotek
    Check it out here!
      im getting the stealthbox so i really can't use that lil cubby. you think there'll be enough room under the front seats and enough room for a back seat passenger's feet?
        Don't know what amp you're using, but I seriously doubt it. Had a look under our front seats? Good luck.
        Red 96' A4 Firebird
        Check it out here!
          Yeah I can barely get my hand under the front seats let alone an amp.
          Just mount it on the back wall in the hatch.
          2006 Tiburon
            Under seats and behind seats is bad ... no ventilation, and it may get beat on. Get your windows tinted ... no one can see what ya got in the car then! ;)
            \'97 Camaro, 3800 Series II, Anniversary Edition * Bright Green Metallic --&gt; T-Tops * Flowmaster Exhaust * TPS Throttle enhancer * SLP Cold air intake .....<br /> <a href=\"http://www.cardomain.com/id/camaro1821\" target=\"_blank\">http://www.cardomain.com/id/camaro1821</a> <br />AIM - Cycochic69
              stick it behind your spare tire. lots of room and its completely hidden...
              disclaimer: \"warning.. this post may contain somewhat of a funny comment if read properly... take my comment out of context at your own discretion...\"
                wish i had a pic of my setup (i'm not gonna try to get one now because its in storage). basically the last one i made was a ported box. i mounted the subs in the well in the trunk. The amps were mounted in the bottom of the box on a removable panle. I routed the ports so i would blow the air from the subs through the amps so it would cool them. I then made a front cover for the top of the box that bolts down. The cover is carpeted to look like a floor to the trunk and has several small holes in the wood below the carpet to allow the air from the ports and the sound through the carpet. It worked out great and if you didnt know the car it looked stock. Hope this gives you some ideas.
