good excuse to... - FirebirdV6.com/CamaroV6.com Message Board
good excuse to...
  • good excuse to...
    get a HO alt for the camaro...
    got to school today, look down "check gauges"
    i check, voltage is below 10 volts... i think its battery... rev the engine, no change...
    turn car off, dont turn over, wait 3 minutes, car starts with trouble...
    and its only from the dealer for 3 days... ****
    White 1998 3.8L Camaro
    Home Ram Air / Free Flow Intake
    Drilled / Slotted Rotors with black painted Calipers
    yeah, that sounds like the problem. you will probably want one for your system anyway. mine is starting to whine like a sc so its only a matter of time.
      would this fall under a powertrain warranty?
      im thinkin i will try to get money for a new alt from the dealer, and put it towards a HO alt
      think the dealer would go for that?
        ive never had warranty work done but i think they would only put a new alternator on not give you the money for a new one (if it is indeed covered in the warranty).
          i wonder if it would be possible to purchase a HO alt through the dealer then?
            well, that was fast... the alt died today, sent into nearest Courtesy dealer, within 5 hours they had a new alt and battery in there... they covered to bill to...
