Kenwood Amp good? - FirebirdV6.com/CamaroV6.com Message Board
Kenwood Amp good?
  • Kenwood Amp good?
    Will this Kenwood amp be good enough to power 2 CVR12's 400watts RMS and 800watts Peak power. The amp price of the amp is $200 what do you think. [img]graemlins/dj.gif[/img]
    KAC-8151D
    GENERAL FEATURES
    - Cast Aluminum Heat Sink: with Sandblast Finish
    - Power Indicator: Blue Logo Triangle
    POWER RATINGS
    - Maximum Output Power: 1000 Watts
    - Power Output at 2 Ohms, at 14.4V (100Hz, 0.5% THD): 400 Watts x 1
    - Power Output at 4 Ohms, at 14.4V (20Hz - 200Hz, 0.5% THD): 200 Watts x 1
    AUDIO FEATURES
    - Class D Operation
    - Ground Isolation Circuit
    - Quiet Turn-On
    - RCA Audio Inputs: Gold-Plated
    - RCA Line Outputs: Gold-Plated
    - Selectable Infrasonic Filter: Off/15/25Hz, 18dB per Octave
    - Speaker Connectors: Gold-Plated, Screw-Type
    - Speaker Level Input Terminals: Plug-Type
    - Variable Low-Pass Electronic Crossover: 50Hz - 200Hz, 18dB per Octave
    - Bass Boost: Off/+6/+9/+12dB (Remotely-Controllable)
    POWER SUPPLY FEATURES
    - 1-Ohm Stable
    - Copper-Shielded EE Core Transformer
    - Noise Supression Filter: Large Toroidal
    - Power Input Terminals: Gold-Plated, Large Screw-Type
    - Power MOSFET Switching Power Supply
    - Power Supply Fuse: 40A
    - Secondary Capacitors: 2 Large
    INCLUDED ACCESSORIES
    - Remote Control for Bass Boost
    95 Camaro 3.4 convertible<br />95 Nissan Sentra GXE Twin Cam
    And what about this other amp its a Lanzar Vibe I can get it for $140. Is it any good? :D
    SPECS ON VIBE241
    2 x 250 Watts RMS at 4 Ohms
    2 x 500 Watts Max at 4 Ohms
    1 x 1000 Watts Max at 4 Ohms Bridged
    2 x 420 Watts at 2 Ohms RMS
    MOSFET Automatically Switches to Maintain Rated Power Over a Wide Range of Battery Voltages
    Stiffly Regulated PWM-Type Power Supplies
    Variable Input Level Controls for Each Pair of Cannels
    Variable High & Low Pass Crossover Controls
    High-Efficiency, Heavy Aluminum Heatsink
    Remote Subwoofer Bass Control
    Electronic Crossover Network
    Bass Boost Circuit
    Bridgeable at 4 Ohms
    2 Ohm Stereo Stable
    Gold RCA Inputs
    Line Outs for Left & Right Channels
    Power & Protection LED Indicators
    Advanced Protection Circuitry
    Soft Turn On/Off
    Frequency Response: 15 Hz-35 kHz
    S/N Ratio: 90 dB
    Dimensions: 10.25"W x 2"H x 15"L
      I linked you to several amps that would work well in your last thread. Remember that you need to be looking at the RMS output when looking at the spec. Any mention of "max", "maximum" or "peak" are just eye catching numbers. RMS value will be NO MORE then half of that. Sometimes even less.
      Kenwood amps are so-so. I'm sure it will put out close to rated power. Believe it or not, Lanzar's Vibe series isin't that bad. Many of their other lines suck balls, but I have read that the vibe series does infact do rated power. If you are looking for the mother of all dollar/watt ratios, then check out the Lanzar Vibe 1200D. Heard fo several happy people using this amp. Here's a non-bias review from car sound. 1262Wx1@14V into a reactive 1 ohm load! :eek: If you are using an aftermerket headunit, note Voltage for Rated Output: 376 mV to 2.9 volts. You probably have 4V RCAs so keep the gain set to min and you should be fine.
      Red 96' A4 Firebird
      Audio Audio and Autotek
      Check it out here!
        96firebird I am running a Clarion headunit 52wX4ch.
        I am going to try to find the Lanzar Vibe 1200D at a car auido shop.
        So one of these amps would you go for Lanzar or Kenwood. Or would neither of these work for me.
        I really need help cause I am going to the audio shop at evening so I really need advice. Thanks.
          Well, out of the two, I guess I'd go with the Vibe. It's does 100 extra WRMS and is cheaper. Like I said, I have heard that the entire Vibe is atleast decent..... also these days 4V RCAs are nearly becoming the standard with aftermarket headunits. With that amp's input voltage range, keep the gain conservative.
          Red 96' A4 Firebird
          Check it out here!
            I just came back from audio shop, I bought a sluger SLD1200 MONO amp for $250. What do you think.
                Never heard of it. 1500watts max huh? Let's hope it really does 1000WRMSx1@1ohm. What is the fuse rating on it? Didn't know you were planning on spending that much. Why buy from a dealer? Nothing wrong with it.... just wondering....
                Red 96' A4 Firebird
                Check it out here!
                  Well that amp is able to pump up 3 of the kickers CVR12 I want to get.
                  Well if would of bought it from the internet that amp would of cost me $289 plus shipping and handling.
                  I bought it from a dealer cause I really trust that audio shop and because they have a great guarantee on the products they sell.
                  I want to buy the kickers at sounddomain.com because the price is a little cheaper, but I dont have any experience buying from the internet.
                    I gave you a brief run down of internet buying in your last topic. Nothing to be scared of. [img]smile.gif[/img]
                    3 CVR's? You only have two now correct? Planning on getting a third?
                    Red 96' A4 Firebird
                    Check it out here!
                      I just sold my old system, and I am just starting to buy my components. I still have to buy the two CVR'S but I was thinking last night what about if I only bought 1 squaured kicer subwoofer would it sound louder than the 2 CVR's. [img]graemlins/rock.gif[/img]
                        The dual 12"s will have more cone area then the single L7..... but remember that you will then only have one sub to power. So double the power to a single sub! With that, they should sound pretty close to one another. Biggest thing being that the overall box size could be smaller now that you're only using a single sub. Maybe enough room to port it? Then the L7 might just pull ahead....
                        Red 96' A4 Firebird
                        Check it out here!
