Cutting a hole for tweeters - FirebirdV6.com/CamaroV6.com Message Board
  • Cutting a hole for tweeters
    What kind of tool would I need to cut a hole for my tweeters in the mirror trim piece? Would anyone recommend somewhere else to mount the tweeter?
    I have a jig saw, but i think i would screw it up with that!
    Thanks,
    Dennis
    i have Kicker components that came with the car, and my tweeters were mounted on the dash, right next to each a-pillar.
    -Justin-<br />Red 1996 Camaro RS- Wrecked 11-1-03...<br /><br />1991 Camaro RS
      keep in mind i think it's ideal to keep the tweeter within 6" of the midrange component.
        <blockquote>quote:</font><hr>Originally posted by TrixTeR:
        keep in mind i think it's ideal to keep the tweeter within 6" of the midrange component.<hr></blockquote>
        It is. But sometimes that's just not feasible.
        Red 96' A4 Firebird
        Audio Audio and Autotek
        Check it out here!
          Usually the 6" is feasable, whether it looks better, well thats questionable. In any event, you might want to dry using a dremel, might work out better for a small space like what you are working with..
          1999 C5<br />2000 Ford Lightning<br /><i>Don\'t hate me because I\'m awesome</i>
            Ya, i know the tweeter is suppose to be close but i don't see any good place for it. The only thing i can think of it putting it in the mirror piece or surface mounting it on the dash. Which one is better between those two?
              You could get some tweeter pods from sshevy on ls1.com. They mount on the inside mirror bracket. But to cut the holes, I would suggest a hole saw. Make sure you know the exact size hole you need to drill and go buy the correct one.
                I'll second Megabass on that one. Try to get ahold of the tweeter pods from SShevy on ls1.com instead of doing a hack job on the stock trim pieces. They're most likely not really thick enough to have a speaker behind them anyway.
                If you insist, you'll need to cut the hole using a hole saw for your drill. A hack saw or a jig saw is going to make a big mess and you'll end up having to replace the stock trim piece anyway.
                HTH
                Mike<br />\'99 Z28 LS1 (383 in the works) M6<br /><a href=\"http://members.fbody.com/drmilhouse/\" target=\"_blank\">stereo pics</a> Almost sold, the amps are still for sale - make an offer.<br /><a href=\"http://members.fbody.com/drmilhouse/paypal.html\" target=\"_blank\">Help Mike pay for his engine. Every dollar helps!</a>
                  I got Trans Am doors with the tweeters built in, they are great. only cost me like 50 bucks for the doors.
                  97 Special Edition Bird , Short bus stlye special
                    What about this?Custom Tweeters
                    1997 Red M5 3.8, 3.23 Gears<br /><b>Performance Mods:</b><br />SLP CAI, RKSport Headers, 3\" Catco Cat, 3\" Cut-Out, SLP S-Pipe, 3\"I-Pipe & over-axle (Custom from shop), Hooker Headers Muffler, Hooker Header Tips.<br /><a href=\"http://members.cardomain.com/redrider45\" target=\"_blank\"><b>My Ride</b></a>
                      also, just so you know, you may only want to drill a hole and put the wires through, if you sell the car, and want to take the tweeters out if you made them flush, there will be a very large hole, and door panels are not cheap, they can range anywhere from $250-$500 each
                      -Steve
                        I used a hole saw. Nice clean cut for me.
                        <b>99\' Black Camaro SS</b> <br />M6/T-Tops - SLPLid w/K&N | Hurst Billet Plus w/ LSS | EGR Mod<p>Black 97\' Camaro T-Tops (RIP)
