buttens - FirebirdV6.com/CamaroV6.com Message Board
buttens
  • buttens
    were can i find cool 12 volt buttens at.
    Whisper lid PPI amp JL 12\" Bosten 6 1/2 Clear coners <br />K&N And hyper white all around 3.73 auburn posi 180* <br />Mangna Flow TransGo shift kit, Jet chip stage 2 <br />Altezzas (carban fiber) <a href=\"http://members.fbody.com/jdyson209/\" target=\"_blank\">http://members.fbody.com/jdyson209/</a>
    I think he means button.
    If you're looking for switches and buttons for your vehicle, your choices are kinda limited. The stuff you see at pep boys/napa/auto zone/orileys/whatever is about it.
    The good news is that you can use almost ANY switch, even very low amperage switches, through the use of relays.
    If you want an obsurd selection of switches, go to Parts Express. Do a search for "switch" and you should get about five thousand results. (just kidding)
    If the switch you like isn't for a 12v application, check the amperage at the given voltage, and do your wattage calculation to see if it's suitable for your application. (Of course you have to know the amperage draw of your application)
    If the switch can't take the amperage, just use a relay. If you need an explanation of how a relay works, just reply. We can help.
    -Brian
    [ July 12, 2002: Message edited by: Brian Dieckman ]</p>
    Maroon 1995 Camaro<br />No mods yet...<br />Lucky to have found this site!
