Ok I had a really bad sub pop when I changed songs on the cd player when I changed songs, but I grounded my rcas and it fixed that but the problem is that when I push the button for the power windows or push the break pedal or shut the doors to my car i get little pop noises from the subs and if I turn the volume down and me just sitting in the car, I can hear noise and some rusling coming from the subs. I also get this with the car off. I also have a A+ ground to the amp itself. Are F-bodies just noisey cars or what? Cuase I had this same setup in my older car with no noise. Im wondering if my rcas are bad?? Any ideas?
Did you use the factory ground when you installed the head unit? Make a good clean ground near the dash and run the ground wire from the head unit to it instead. Factory ground wires are used for many things so they tend to be noisy. Let me know if this helps.
