Got my wiring situation all worked out but now my subs appear to turn on only when they want to or if i turn the volume up loud enough. I mean I can hear them turning on or off? Anyone have any idea what could be wrong or is this normal? I mean this happens in the morning also, so it's not like the amps are over heated. help!
Subs turning on and off??
on many amps there is a power protect mode when either the power is too low to the amp, to high, or the subs are being over driven, I had a 300 watt sub on my 1000 watt amp ( sub was mislabled) and the amp kept shutting off when I would turn it up a little or on a strong bass hit. A friend of mine also had a setup once where he used the wires from his rear speakers as the input for the amp, which was giving bad signal and was over driving his subs. fixed with an amp with preouts.97 Special Edition Bird , Short bus stlye special
Takumi probably hit it on the head with what's wrong, but I had a similar situation where my system would turn on and off....so on and so forth. Ended up being the remote circuit in my amp. I think it's probably the "power protect" like said earlier though.Nitrous is like a hot chick with an STD....you wanna hit it, but you\'re affraid of the consequences...<br /><br /> <a href=\"http://www.cardomain.com/member_pages/view_page.pl?page_id=244935\" target=\"_blank\">http://www.cardomain.com/member_pages/view_page.pl?page_id=244935</a>
might just be overheating the amp too.2001 Blue Firebird.<br />V6 M5. free ram air mod, 3\" pvc intake, Air temp module, 3\" exhaust, Dynomax 3\"straight through exhaust, O2 sim with off road pipe.<p>Kenwood kdc-mp919 head unit, kfc-628 and kfc-748 amps, Kicker I650 mids/highs, 12\" kenwood WS-303 sub<br /><a href=\"http://www.trafficjamzcaraudio.com\" target=\"_blank\">www.trafficjamzcaraudio.com</a><p>1500 years ago the world was the center of the universe. 500 years ago the world was flat. 15 minutes ago we were alone on this planet. Just think what you will know tomorrow.
Usually overheating on most amps is due to a bad remote setup, as in wiring the power that goes in the 12v slot right to the remote with a short wire. causes MASS HEAT beacuse of the physics between changing wire gauge like that causes heat. Bad signal- heat makes lots of resistance in the wire, and the hotter the wire gets more and more resistance, so hence it'l shut ur amp off cause it thinks its getting a resist setting from the deck. Or its what i said before =)97 Special Edition Bird , Short bus stlye special
