Is this it? - FirebirdV6.com/CamaroV6.com Message Board
Is this it?
  • Is this it?
    ok, I'm making a checklist of everything I need for my new system.
    I want to keep my factory HU and add 4 speakers and 2 subs in the hatch.
    Besides the subs/box/speakers and the PAC OEM-1, what else will I need?
    Is this job gonna be easy?
    2000 Light Pewter Metallic<br />RIP...15FEB03
    <blockquote>quote:</font><hr>Originally posted by Cam Massey:
    Is this job gonna be easy? <hr></blockquote>
    No. lol just kidding man. It's not that hard. Are you planning on making the box yourself? That can be tricky in our cars. You can buy really nice customs sub boxes from www.subthump.com Some of these allow you to keep t-top storage. (if you have t-tops!!)
    <blockquote>quote:</font><hr> Besides the subs/box/speakers and the PAC OEM-1, what else will I need <hr></blockquote>
    You forgot one of the biggest things... AMPS!!!!!!!!!! They give you all the power to drive your speakers. The Pac Oem-1 gives you 2 sets of RCA's out (I think) you will run these to your amp or amps. If you want to save some money, I recommend getting a 5 channel amp, but it's going to be tough finding one powerful enough to drive 2 subs. You might have to go with 2 amps. And don't forget wiring!
    Red 96' A4 Firebird
    Audio Audio and Autotek
    Check it out here!
      96firebird311 beat me to it.
      Amp wiring kit, speaker wire, fuses. Just basic stuff. D-block if you will have more than one amp. Actually two D-blocks, one for the ground wires as well.
      [ July 16, 2002: Message edited by: SunsetOrange98Camaro ]</p>
      <b>1998 Cayenne Red Camaro 3.8 A4</b><br />-Whisper Lid, K&N, manual fan switch, DEI 508D<br /><br /><b>FOR SALE:</b><br />-Whisper Lid<br />-PAC OEM-1 adapter<br />-GM Delco 12 disc CD Changer<br />-MTX 4250D amp<br />-Kicker Free Air subs<br />-DEI 508D Proximity Sensor
        <blockquote>quote:</font><hr>Originally posted by SunsetOrange98Camaro:
        Actually two D-blocks, one for the ground wires as well.<hr></blockquote>
        Why would he need a d-block for the ground wires? Unless he was running them all the way back up to the battery..... really no need for that though.
        Red 96' A4 Firebird
        Check it out here!
          He will need a D-block for the ground wires because usually you want to use the same ground for all your equipment, at least thats what I've heard. I have a d-block on the back wall of my car for my ground wires. I have a 4 gauge ground wire connected to the piece of metal that holds the trunk catch mechanism. The 4 ga. wire goes to the d-block which has (4) 8ga. inputs. I have two being used for both of my amps, and one for my neons, crossover, and relay. You could just put ring terminals on all of these wires and connect them to the same screw but I find it alot easier to just screw one wire to the metal and attach everything else to the d-block.
            SunsetOrange98Camaro is Right. If you run a two amp set up you will need two distribution blocks (D_blocks) the one for the power wire should be fused and the ground block can be just a plain cheap d-block. It is not good practice to jump a ground wire from one amp to another, b/c there is the chance that if one amp goes bad it could screw up the other one. With a d-block= no problems.
            I wouldn't suggest building a box for these cars, it's a b**ch. I tried but was both unpleased with the look and sound so I went with the q-logic and expanded the chamber size
            just my .02
            Michael
            1999 A4 Black Firebird<br />17 x 9.5 ROH ZS Wheels powdercoated Black<br />Wings West Front GFX, Y87 Sides and Rear<br />2000 SS leather Seats<br />Alpine HU, Kicker Mids and Highs Diamond 12\" subs, JBL600.1 amp, Epicenter<p>\"All Show, NO GO\" :(
              <blockquote>quote:</font><hr>Originally posted by superbird:
              and the ground block can be just a plain cheap d-block. <hr></blockquote>
              Not CAN be, SHOULD be! You never fuse a ground wire!!! I'm not talking jumper ground wries from amp to amp. Both of my amp are about 1 foot from the ground location so I just ran two short pieces of wire to the grounding point. A d-block for power wire will break it into smaller wires that your amp with accept. There is no reason to do the opposite for ground, it doesn't care what size wire it has!! A d-block won't do anything for ground except maybe save some wire. Yes, you should try to use the same ground for all of your equipment.
              Red 96' A4 Firebird
              Check it out here!
                <blockquote>quote:</font><hr>Not CAN be, SHOULD be! You never fuse a ground wire!!!<hr></blockquote>
                I think thats what superbird meant. Im assuming he was saying you dont need to buy a fancy, aerodynamic, expensive d-block-just a plain cheap one.
                <blockquote>quote:</font><hr>There is no reason to do the opposite for ground, it doesn't care what size wire it has!!<hr></blockquote>
                Oh really, thats new to me. So you can ground a 500 watt amp with an 18-gauge wire?? Always use the same size wire for ground that you do for power, ALWAYS!! Bigger wire is fine too, as long as its not smaller.
                [ July 18, 2002: Message edited by: SunsetOrange98Camaro ]</p>
                  That's not what I meant either.... so I guess we're even! [img]smile.gif[/img]
                  Red 96' A4 Firebird
                  Check it out here!
                    Sounds good to me :D
                    I didnt think thats what you meant, I just like to throw a little sarcasm in every chance I get. Trying to liven this board up some.
                      Thanks SunsetOrange98Camaro
                      Georgia boys have to stick together!!!
                      and 96firebird311 that is what I meant. I would never use a fused ground block. I just meant that you don't have to go out and buy a 30.00 ground block from stinger. I have a stinger + d block and a cheap negative with a stinger sticker on it. Only 2.50 on ebay. Plus I like the d-block setup becuase it makes for a clean looking install.
                      IF you really want to get some power to your amp why don't you just run 20 GA from the battery back. [img]smile.gif[/img]
                        <blockquote>quote:</font><hr>Thanks SunsetOrange98Camaro<hr></blockquote>
                        Your welcome!!
                        <blockquote>quote:</font><hr>Georgia boys have to stick together!!!<hr></blockquote>
                        Exactly :D
