I'm going to put a system in the car this spring and it's going to have one 10" sub. I've heard the Stealthbox is better than the Thunderform. Is this true and why?
Also the sub I'm putting in is a Digital Audio DAW1000
specs:
120 oz. Double Stacked Strontium Magnets | Power Handling: 600 watts R.M.S. | Frequency Response: 23Hz Ð 500Hz | Efficiency: 91.1 dB | HUGE 2 Inch Foam Surround | Non- Pressed, Non-Transfer Paper Cone | Coated for Virtually No Cone Distortion | 2 Inch 4-Layer ASV Voice Coil | Dual 4 Ohm | 2 Ohm or 8 Ohm Operation Chrome Plated, Cast Aluminum Basket* | Machined Chrome Back Plate | Extended & Vented Pole Piece |Nickel Plated Lug-Lock Terminals
Thanks for any input!
-Andrew
specs:
-Andrew
